Can I Use Anything Other Than Mortar Under The Hardie Board - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 06:18 AM   #1
Rewards Points: 51
can i use anything other than mortar under the hardie board
I am wanting to save time can I use anything else.to bond the Hardie.board to the subfloor like construction adhesive or something
joelowrider is offline   Reply With Quote
Old 07-17-2012, 06:26 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 114
No...............
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-17-2012, 06:32 AM   #3
DIY staff
Rewards Points: 7,174
No--the thinset is there to FILL VOIDS--not to bond the hardie to the floor---use powdered thinset.
Old 07-17-2012, 08:47 AM   #4
Rewards Points: 13,724
Any DIY job is at least 50% prep work, skip a step and most likly the whole job fails.
Just how fast will it be when the tiles and grout crack and it all has to be done over?
Old 07-17-2012, 09:26 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 388
Joelowrider,
Guess they told you? They are absolutely right.
Most people, (including many that install tiles often), do not understand why the need for thin set under all concrete backer boards. Like you they think it's to bond it to the floor. The thin set holds the board up, the fasteners hold it down. Without the supporting layer the board will move a tiny bit and over time you're likely to have some grout cracks or worse.
Jaz
Old 07-19-2012, 02:01 AM   #6
Originally Posted by JazMan View Post
Joelowrider,
Jaz
I'm assuming you screw the concrete board down while the mortar is still wet?
Novice_DIY is offline   Reply With Quote
Old 07-19-2012, 02:02 AM   #7
Joelowrider,
Jaz
Old 07-19-2012, 06:18 AM   #8
DIY staff
Yes--screw or nail while the mud is wet.
This is where logic and common sense come into play----short of writing a book in order to help a member--the pros here often assume that a member will figure out the steps needed to complete the job.
Not all posters have those two helpful qualities----Mike---
hardie board for floors npeswillie Flooring 8 03-11-2012 10:49 PM
Hardie Board jonathan03 Flooring 10 07-29-2010 12:50 PM
hardie board nap Building & Construction 5 06-03-2010 07:18 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 10:03 AM
Hardie Board Vs.....? tattood General DIY Discussions 2 08-10-2005 09:26 PM
