-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Can I tile over painted concrete? (http://www.diychatroom.com/f84/can-i-tile-over-painted-concrete-96676/)
MarcelFt 02-26-2011 10:33 PM
Hey, new to this site, thanks for taking the time read:
I want to put Mexican tile down on a concrete floor. 1/3rd of the floor is painted, with what I think is epoxy as it's very tough. The rest of the floor has linoleum tiles, which peal up very easy, and under them is a black coating of some kind. The floor is also not level in all areas, and I will need to level it with self leveling compound.
Bud Cline 03-01-2011 06:06 PM
No.:)
MarcelFt 03-01-2011 10:31 PM
Originally Posted by Bud Cline (Post 600602)
No.:)
Bummer. :(
So, I looked around, seems like I need to rent a scarifier and grind it off huh? Anything else that may be easier?
Bud Cline 03-01-2011 11:00 PM
Bonding to paint or trying to bond to paint is problematic, trying to bond to epoxy paint is basically hopeless.
The paint can be sandblasted or shot-blasted or mechanically ground away. Shot-blasting is the more efficient method with less mess. The biggest problem is getting ahold of the equipment to do the work. Shot-blasting is mostly reserved for those in the business of shot-blasting that own their own equipment.
I have had good luck grinding but I'm talking about using a walk-behind grinding machine that I rent from a tool rental company. You rent the machine and buy the grinding stones. There are also machines that use a diamond impregnated disc but the discs clog easily and can't really be cleaned and they are very costly with little bang for the buck. The best-bet is the rotary-type machines (IMO) that use carbide teeth that scrape/grind away the coating. I have had my best luck with this type of machine. A good rental machine to seek out is the EDCO. It is a rotary machine that uses carbide teeth - you buy the teeth and rent the machine.:)
