My kitchen has countertops and a backsplash that are made of an AWFUL laminate. The reason it's awful is because it is textured to look like mottled stone. I don't like the look of it. I'm not ready to deal with the countertops, but I would like to do something about the backsplash.
The problem is that the previous homeowners put up these sheets of laminate backsplash material UNDERNEATH the cabinetry - so, if I wanted to take down the laminate, I would have to remove all the cabinets. I don't want to remove or replace the cabinetry right now.
I have a very large number of glass block "marbles" - they are about 1" square and maybe 1/2" thick. I think they'd make a great looking backsplash.
So, I have three questions:
1. Is there a thinset or other type of adhesive material that will adhere to both the glass and the laminate?
2. Is this a smart project idea in the first place - that is, are there risks associated with putting up glass (which I know can get heavy) over laminate that extends UNDER the cabinets? That is, will the weight of the glass ultimately cause the laminate underneath to pull forward and/or damage the cabinets?
3. Are there other questions I should be asking that I don't even know to ask??
Thank you all so much --
Corey-Jan
Corey-Jan
