Can I Install Mesh Back Mosaic Tile Directly To Primed Drywall - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-16-2009, 01:09 PM   #1
Can I install mesh back mosaic tile directly to primed drywall
Hello All,
First time here and I have a question. I have purchased 12"X12" mesh backed glass mosaic tiles (1 inch each) to be installed on an entire wall in my bathroom. The wall currently is primed drywall. Can I install directly to that wall or is there an other prep step I need to do?
Thank you so much,
Jen
jenrao9991 is offline   Reply With Quote
Old 03-16-2009, 08:21 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Hi Jen,
Tile can go over wallboard as long as it's not a wet area. What adhesive were you planning to us for these glass mosaics? Glass tiles are very finicky, what does the maker say?
Jaz
Old 03-16-2009, 09:04 PM   #3
Products to use on glass mosaic
Hi Jaz,
Thanks so much for the reply.
I've purchased the following:
Versabond fortified thin-set mortar in white and Thinset mortar admix to use in place of water.
Think that'll be OK?
Thanks again,
Jen
Old 03-16-2009, 10:19 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 388
NO. You do not use additive with modified thinsets. You mix them just like it tells you on the bag.
If you insist on spending more money, get a better thinset. Although Versabond will work for most projects, it is an entry-level quality product. Nothing to brag about. What's an extra 10 bucks?
Jaz
Old 03-16-2009, 10:24 PM   #5
Hi Jaz
Thanks again...really! I need all the help I can get.
What do you suggest for thinset? Can I get this at my local home improvement store? Do you think I should nail through the mesa once adhered to keep it in place while drying?
Jen
Old 03-17-2009, 06:08 PM   #6
Rewards Points: 5,336
Jen
You do not need to nail through the mesh to keep the tile in place. The thinset will do that as long as you make sure the tile is imbedded into the thinset. After you place the sheet, use a grout float to tamp the sheet in place. After you tamp it, check to see if it has shifted and make any adjustments you need to.
Ron
Can I install Kerdi over primed drywall in a basement bathroom? Mechelle Tiling, ceramics, marble 13 04-22-2012 10:50 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
a couple of ceramic tile install Q's DanBress Flooring 5 06-22-2008 10:01 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
