Can I Hang Tile To Drywall? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 07:07 AM   #1
can I hang tile to drywall?
Can I hang tile to drywall?
joesellers is offline   Reply With Quote
Old 03-01-2011, 07:23 AM   #2
DIY staff
Rewards Points: 7,174
Absolutely,its done all the time. What kind of tile --where is it?
Old 08-21-2014, 02:44 PM   #3
Not recommended... depending on tile type, the weight of tiles can pull the drywall loose from the screws. If you do it, double up the number of screws holding the drywall to the studs and be sure not to drive the screws into the drywall more than a "dimple." You want your install to last years and years, not just a year or two.
Galileo007 is offline   Reply With Quote
Old 08-21-2014, 02:52 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,492
Interesting.....
But considering that Mike has been making a living for ever (old guy) doing construction, I'm inclined to believe him. Besides, I don't buy tile being able to pull drywall down. The adhesive would pull the paper off the drywall before the screws gave way, especially on walls where the force is in shear.
ddawg16 is online now   Reply With Quote
Old 08-21-2014, 03:36 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 346
Galileo,
Where did you get that idea? Absolutely wrong!
You can bond, (not hang) even thin bricks and stone. The weight is spread out over the entire area, it's not localized.
Care to introduce yourself and give a short bio so everyone can get to know more about you?
Also when you have something on your mind, it's best to start your own thread and not resurrect one that was buried years ago.
Jaz
Old 08-21-2014, 04:20 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
"Not recommended by who"?
In my almost forty years of installing tile everywhere imaginable this is the first I have heard that. It just simply isn't true.
Keep in mind there are professionals that participate here and have many years of experience. When bad advice or poor information is dispensed you are going to be challenged.
Welcome. Now...Who are you and what experience do you have?
XXX
Old 08-24-2014, 09:26 AM   #7
Rewards Points: 4,796
Extremely unlikely. The weight of tile or other coverings can be quite high, that's true. But that downward force is perpendicular to the drywall screws, and also spread out across the entire face. There is very little force pulling in the direction outward on the screws. In fact, it might even be pushing inward if your walls aren't perfectly plumb (and many are not).
Now if we are talking about tiling a shower ceiling, you'd be correct. You'd be wise to double the screws in that scenario.
Dimpling is simply standard drywall practice, nothing special needed in this case. Keep in mind that longer screws should definitely not be used. It might seem counterintuitive, but drywall screws should be 1 1/4" for 1/2" drywall, not longer. You can actually get warps and pops if the screws are longer because of movement in the studs. If the screw were 2" for example, so much of it is in the wood that as the stud expands and contracts, it can pull on the screw too much. Not to mention the fact that you'll be piercing an electrical wire that way at some point
jeffnc is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 05:49 PM
Best way to hang drywall? 737Pilot Drywall & Plaster 15 07-20-2008 08:06 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
