Can The Drywall Support The Tiles? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 09:09 AM   #1
Can the drywall support the tiles?
We are renovating our bathroom. Our porcelain tiles are 24 x 12. My question is with a good quality adhesive can we apply these tiles to drywall or do we need to replace the drywall with cement board? Many thanks,
HeidiT is offline   Reply With Quote
Old 02-26-2012, 10:08 AM   #2
DIY staff
Rewards Points: 7,174
Drywall will be fine---use a powdered modified thinset---"Mud" What Is It? - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
With those huge tiles --consider using leveling clips, to avoid lippage-(uneven tile edges)QEP | Lash
Tuscan Leveling System - Flooring Picture Post - Contractor Talk - Professional Construction and Remodeling Forum
HeidiT (02-26-2012)
Old 02-26-2012, 10:10 AM   #3
Rewards Points: 512
cement board is prefered but yes drywall can support it with the proper thinset for wall tiles.
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
HeidiT (02-26-2012)
Old 02-27-2012, 10:38 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Umm... I know you didn't ask this, but your other two threads are about showers. Are these shower walls?
If so, tell us you're using Kerdi. Otherwise drywall in a shower is not a good idea.
The Following User Says Thank You to Blondesense For This Useful Post:
oh'mike (02-28-2012)
Old 02-27-2012, 11:24 PM   #5
long island, NY
yeah, never drywall in a shower...
in our powder room we have 12" x 36" porcelain tiles with 1/16" grout lines all the way to the ceiling... on drywall. We purchased them at porcelanosa (a store representing the tile manufacturer) and asked detailed questions about both the thinset/grout they recommend, and the notch of the trowel. I vaguely remember a 1/2" notch.
about 2 years later, and the walls are still flawless.
diy'er on LI is offline   Reply With Quote
Drywall Damage After Wallpaper Removal katega Drywall & Plaster 1 01-28-2012 11:11 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 07:29 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
How To Support A Drywall Patch For Hole In The Wall? dsq Drywall & Plaster 7 02-23-2009 03:48 PM
Replacing a few individual tiles in bathroom - chiseled a bit into the drywall Pickngrin Drywall & Plaster 4 12-28-2008 07:40 PM
