Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 02-18-2013, 09:58 AM   #1
Bullnose this tile
1st- thanks to all who help on this site....it's great!!!
She picked it I layed it...I think it's travertine. I'm looking to round or bullnose the edge. I've been reading and just want to confirm that because travertine is soft a beltsander and sandpaper starting at 60grit and going to 350 is all that is needed. The tile is 1/2 inch.
Any advice that would help ?
Chip
Bullnose this tile-image-1045123181.jpg   Bullnose this tile-image-3352888436.jpg
chipraynor is offline   Reply With Quote
Old 02-19-2013, 05:19 PM   #2
Bullnose this tile
The travertine will take a bullnose nicely. I usually take an angle grinder with a diamond blade to do a rough bevel and then use a palm sander w/ 60 grit, but your method of using a belt sander sounds good as long as you finish it with a palm sander (more mobility to round the edge). I usually fabricate a model and keep it to make sure the following bullnose look the same, as you pretty much have to eyeball it.
Frattman is offline   Reply With Quote
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 03:29 AM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 01:03 PM
Bullnose Tile - how to do it? tjawed Flooring 4 06-02-2010 11:51 AM
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
