Bullnose Drywall Casing Meets Backsplash - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 11:10 PM   #1
Bullnose drywall casing meets backsplash
Im redoing my kitchen. I took it down to the studs and installed a 36 inch window centered above where the sink will be. Im going to make a granite window sill.
The top 23 inches or so of the window casing will be drywall with bullnose corners. Im going to do a full 18 inch backsplash inbetween the upper cab's and the counter. This backsplash will wrap around forming the lower foot of the window casing. Where tile meets tile on the window casing will make a perfect 90. This 90 up against the bullnose corner of the drywall will leave an unsightly gap thats boggling my mind. I though about using a bullnose to 90 transition corner designed for baseboard but I dont like the look. Only other thing I can think would be some caulking or some grout which isn't too appealing either.
You tile guys got some tricks or suggestions?
conspikuous is offline   Reply With Quote
Old 02-07-2012, 07:11 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
How does the sheetrock bullnose look against tile bullnose?
Edit: Never mind. I think you have a different situation going on if I'm reading it right.
titanoman is offline   Reply With Quote
Old 02-07-2012, 07:23 AM   #3
Rewards Points: 13,752
Pretty common problum that's going to require compromise.
Use bull nose tile (the 2" wide not the base cap) as a casing, or use real wood casing held back away from the radis, keep your tile below the window stool.
Old 02-07-2012, 10:50 AM   #4
firehawkmph's Avatar
Rewards Points: 1,884
Cons,
why not just stop the tile short of the bullnose radius in the wall and use a tile with a finished edge (bullnose tile)? In other words, don't wrap the lower jamb with tile. How bout some pics?
Mike Hawkins
firehawkmph is offline   Reply With Quote
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
Drywall Damage After Wallpaper Removal katega Painting 10 01-26-2012 10:21 PM
drywall meets hardi backer get'erdun Tiling, ceramics, marble 4 01-08-2012 08:47 AM
where tile backer meets drywall rtoni Building & Construction 11 01-07-2011 09:05 AM
Where new drywall meets old. brneilly Remodeling 4 02-19-2008 09:18 AM
