Bullnose Corner Tile For Backsplash - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 08:08 PM   #1
Bullnose corner tile for backsplash
The tile I chose for the kitchen backsplash has bullnose tiles with a single edge but no corner pieces available. How do I make a corner piece so the bullnose edge is on both the side and top of the corner tile? I think I would cut 2 pieces on the diagonal but I can't picture it and I want it to look right. I am new to tiling, this is my first tile project. Thanks.
golfgirl is offline   Reply With Quote
Old 03-03-2010, 08:36 PM   #2
Bullnose corner tiles for backsplash
I posted this in the wrong place so I apologise if you already read this.
I am new to tiling, this is my first project. The tile I chose has single edge bullnose pieces availabe but no corner pieces. How do I make one for a corner? Do I take 2 pieces and cut in 1/2 on the diagonal to make 2 bullnose edges. I think I am right but I can't picture it. I want it to be right and not look sloppy. The tiles are all 4 x 4.
Thanks.
Old 03-04-2010, 06:27 AM   #3
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
You could take two of the edge bullnose and cut them at a 45 degree angle to the corner. Just make sure you watch out for what corner you cut to. Then put them together and bam bull nose corner.
Big N8 is offline   Reply With Quote
Old 03-04-2010, 08:12 PM   #4
That was sort of what I was thinking would work but I was not sure it was the right way. Even though I am a newbie, we have invested too much to have the final piece look cheap. Thanks for your reply and help.
Old 03-05-2010, 06:16 AM   #5
what you said. Cut two tiles at opposite 90deg angles, and you have a corner.
Old 03-05-2010, 06:11 PM   #6
Thanks. At least now I know I am on the right track.
Tile to outside corner - cleaning up edge RDS Kitchen & Bath Remodeling 8 11-23-2014 12:49 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
corner tile shower jimmy21 Plumbing 2 05-25-2009 10:12 AM
How to mitre bullnose corner bead?? Arbs Building & Construction 3 01-28-2008 12:32 PM
Repair damaged bullnose corner DRCollier Building & Construction 2 07-15-2007 09:46 AM
