Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 07-15-2012, 05:48 PM   #1
Broken Wall Mount Ceramic Soap Dish
I have a wall mount soap dish that's broken.
There is a place I believe that sells something like this 70s style ceramic soap dishes. May be I can find a match.
Now assuming I can find a match, what is the best way to repair this?
I assume this is just laid in thinset like a normal tile?
If I take an angle grinder with a diamond blade, score the four edges of this thing, I am hoping with a chisel I can dig out the whole thing right?
miamicuse is offline   Reply With Quote
Old 07-16-2012, 03:44 PM   #2
sdsester's Avatar
The approach you describe sounds like a good plan. However, as I look at the picture it looks like the soap dishes are larger than the tiles behind them? They appear to mounted to the surface of the tile? If this is the case they may have been installed with construction adhesive, epoxy or something. Something like a multi-tool or thin cold chisel slipped between the tile and soap dish might be the tool of choice. If you break the tile you may find yourself having to replace the tile and the soap dishes.
sdsester is offline   Reply With Quote
Old 07-16-2012, 11:22 PM   #3
Thanks.
That is what is difficult to tell, whether it was installed OVER existing tiles, or whether it has a "lip" like these.
So these have a smaller area behind the dish that fits into a tile space.
Old 07-17-2012, 10:04 PM   #4
Originally Posted by miamicuse View Post
Thanks.
in my experience = bingo.
i would remove it as if it were an actual tile.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Recessed ceramic soap dish in tile shower Kiki D Tiling, ceramics, marble 2 04-10-2012 06:34 PM
How to fix Ceramic towel rack that got knocked out of the wall? There are 2 square holes now on each side to the wall? nicki3174 Kitchen & Bath Remodeling 8 11-21-2011 10:08 PM
Wiring for a wall mount flat screen Badfish740 Electrical 4 01-13-2010 08:21 PM
How to mount an enclosure to exterior wall with vinyl siding? biglaz Building & Construction 3 05-30-2009 11:13 AM
white stains improvements Appliances 1 02-20-2009 05:26 PM
