Broken Drill Bit - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-19-2009, 06:46 PM   #1
broken drill bit
I was drilling holes for my shower door in ceramic tile and broken the bit off inside the hole. Can anyone tell me how to remove that broken piece from the hole?
ricemaiden is offline   Reply With Quote
Old 04-21-2009, 11:21 AM   #2
Rewards Points: 26
Is the broken bit sticking out of the hole at all? What does the bit look like? If it is fluted(spiral shape) you might be able to use a needle nose pliers to pull it out. Once you break a drill bit off they usually are stuck where they areif you can't get them with a pliers. Can you drill another hole somewhere and just caulk the one with the broken bit?
ponch37300 is offline   Reply With Quote
Old 04-22-2009, 09:29 AM   #3
Broken dill bit
Thanks for your interest but, no you can't see it so I think, as you say I'll have to move either up or down. It will be covered with the shower door frame. I gave up and ordered a diamond bit from CA so hopefully it will work.
Broken drill bit in expensive tiles. Oops. manuelhung General DIY Discussions 9 01-24-2016 05:10 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Help with broken drill serill Tools 2 09-07-2008 11:14 PM
Broken Drill Bit . . . chins01 Remodeling 4 01-24-2008 11:38 PM
Broken Drill Bit Freelancer General DIY Discussions 15 03-29-2007 04:01 PM
