Brick Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-30-2011, 05:54 PM   #1
Porcelain Tile
HELP! I am having my nearly century old brick chimney and fireplace re-lined and tuck pointed. The hearth is constructed of porcelain tiles, with a smooth surface. The tiles were possibly glazed, although dulled now. Anyway, I arrived home after the contractor had left for the day and noticed one of the hearth tiles was missing. When I called, he asked if it was there before they had started work, which IT WAS. He said they'd have to replace it, but obviously, it will be virtually impossible to do that. I have no idea what they did with the missing tile. Not sure what to do now . . . I am afraid that any replacement tile will just look wrong. Replacing the entire hearth is cost prohibitive and I wish to maintain the original look, anyhow. I did find a site on the net, which does replicas, but OUCH--the $750 minimum order is much too expensive for my budget. Any suggestions will be appreciated--thanks!
jane99 is offline   Reply With Quote
Old 05-01-2011, 01:36 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Replacing one brick will look like odd mismatch. If you could find something close, it might be possible to replace several in a pattern so it would look planned.
The Following User Says Thank You to Blondesense For This Useful Post:
jane99 (05-01-2011)
Old 05-03-2011, 04:29 PM   #3
Correction
I have decided that they are actually porcelain tiles, not a type of brick. Wondering if anyone makes custom tiles . . .
Old 05-04-2011, 12:47 PM   #4
Stuck in the 70's
Google is your friend, but I suspect it would be more cost effective to replace the hearth.
HELP! with brick tile floor cpmathis Flooring 0 09-03-2010 10:58 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Stick-on tile over Stick-on tile Chris_Old_House Flooring 2 09-27-2008 08:45 AM
