Big Or Little? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-20-2013, 03:27 PM   #1
Rewards Points: 31
big or little?
If my bathroom floor is less than ideally stiff, would small tiles or big tiles be more forgiving? We're talking about an 8' X 8' room.
gulleyj is offline   Reply With Quote
Old 08-20-2013, 03:43 PM   #2
Old School
Willie T's Avatar
Neither. Get the floor shaped up, if at all possible.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
user1007 (08-20-2013)
Old 08-20-2013, 04:39 PM   #3
Too Short? Cut it Again!
I flexing subfloor will cause the mortar between the tiles to fail and/or the tiles to crack whether little or big.
Old 08-20-2013, 04:47 PM   #4
Rewards Points: 258
If you don't want to reinforce the floor consider sheet vinyl or vinyl tiles.
Being human is the result of heredity.
Being humane is a matter of choice.
retired guy 60 is offline   Reply With Quote
Old 08-20-2013, 05:41 PM   #5
Sheet vinyl, cut to fit but not glued might work. If the floor is flexing, you are likely to pop vinyl tiles loose too.
