Big Ditra Mistake - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-06-2015, 12:39 PM   #1
Rewards Points: 2
Big Ditra mistake
Help! We put down ditra on modified thinset over wood subfloor in our bathroom. We have hills and valleys maybe from kneeling on. They make it look so easy on-line. We pulled up the ditra a few days later and tried to chisel the modified thinset in order to start over. This was online recommendation This stuff isn't coming up. What do we do now? Our tile (ceramic long pieces that look like hard wood 5 inches wide) requires unmodified thinset. Can I put tile with unmodified right on dried modified thinset and forget the ditra. Start at highest point and make sure other tiles have enough thinset to meet the first.
What's a girl to do
Try2DIY is offline   Reply With Quote
Old 06-06-2015, 04:22 PM   #2
iminaquagmire's Avatar
Rewards Points: 318
Big Ditra mistake
Definitely don't just go over the plywood. A diamond cup wheel will make short work of any residual thin set left on the plywood and you can start over.
iminaquagmire is offline   Reply With Quote
Old 06-10-2015, 05:15 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 3,354
Big Ditra mistake
Sorry you're having a problem, young lady. I don't see how dimples from kneeling can cause a problem that would hamper the installation of tiles unless the floor was not flat in the beginning. Are you sure those are not air pockets? You have to start with a sturdy flat floor and your selection of tiles require a very flat base.
You can not do as you describe. Porcelain tiles over Ditra set with a high quality unmodified is right. If there's no Ditra, you'll need to use a modified thinset. But Tile without a Ditra type membrane or concrete backer is not a good plan.
Jaz
Tile 4 You LLC Troy, MI - Consulting by phone/internet -PAYPAL
DITRA Installs - KERDI Watertight-Mold-Free Showers. I have NEVER made a mistake, I thought I did ONCE, but, I was WRONG! A+ BBB rating - est. 1987 - over 50 yrs. exp.
JazMan is online now   Reply With Quote
The Following User Says Thank You to JazMan For This Useful Post:
gregzoll (06-10-2015)
Old 06-10-2015, 05:53 PM   #4
Rewards Points: 3,772
Big Ditra mistake
I agree with Jaz and that was my first impression. Either the floor had strange irregularities to begin with, or you didn't step on the floor enough - i.e. you have bubbled up areas.
Thinset isn't really tough stuff like grout or concrete, so you should be able to get it up with standard techniques - multi-tool, grinding wheel, etc.
Sounds like you have faux-wood tile planks. You are going to have a hard enough time avoiding lippage with those long tiles as it is. You want a very flat surface to begin with.
jeffnc is offline   Reply With Quote
Old 06-15-2015, 06:53 AM   #5
Rewards Points: 230
Big Ditra mistake
Yeah to what jeffnc said. It's all about having the right tool. I used a Dremel Multimax with a scraper blade to remove thinset and adhesive from my bathroom subfloor. A grout removal blade would probably shave it right out too. It will take some work, but you can get it out.
Another option is to put an "gig" ad on Craigslist. Someone with the right tools could make short work of it and you could can get back to work.
Good luck.
costgeek is offline   Reply With Quote
Old 06-24-2015, 02:40 PM   #6
Amateuralex's Avatar
Rewards Points: 258
Big Ditra mistake
A hammer, a chisel, and some armwork really, really should do it.
Amateuralex is offline   Reply With Quote
Tags
ceramic tile , ditra , mistake , thinset thickness
Wrong Trowel Size over Ditra Cabrios Tiling, ceramics, marble 3 01-31-2014 08:45 AM
Replacing 2 ceramic tiles over Ditra RichardZ Flooring 33 01-17-2013 12:22 PM
Ditra or Hardibacker? bluefoxicy Tiling, ceramics, marble 15 01-10-2013 09:00 PM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
