Bevel Porcelain Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 08:36 PM   #1
bevel porcelain tile
How do you bevel the end of a piece of porcelain tile?
Elaine W is offline   Reply With Quote
Old 02-02-2011, 09:10 PM   #2
Registered User
Rewards Points: 4,924
Welcome to the forum!
I'm sure someone with tile experience will answer soon. Please do not hit the "report a post" button unless reporting to the Moderators some spam or name calling in an answer, as per site rules.... Thank you.
Someone will be along shortly...
Gary
Old 02-02-2011, 09:11 PM   #3
For what purpose? Making a bullnose piece?
FlooringDude is offline   Reply With Quote
Old 02-06-2011, 11:47 PM   #4
take them to a stone fabricator as he/she will have the necessary tools to put a bevel on porcelain tile. if u want to do yourself purchase a variable speed grinder (u can work slowly with one), and a set of polishing pads for stone with a rigid backer. utilize utube for making bevels. utilize the techniques u feel comfortable with. myself, i start with the 50 grit polishing pad and keep it at an angle on the tile. cut the bevel to the depth u desire with the 50 grit pad. finish off with the rest of the pads always keeping the pads in contact with the tile so as not to make ripples. use constant pressure. not too firm, not too soft. try a practice piece first.
acglobal is offline   Reply With Quote
Old 02-09-2011, 11:59 PM   #5
When I have need to take the sharp edge off of a porcelain tile cut, I hold the tile at 45 degrees to the wet saw table and run the top of the cut edge along the side of the saw blade. This takes the sharp edge off nicely.
Tile Pro is offline   Reply With Quote
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 10:32 PM
Subfloor and Porcelain tile prep sugarhousemama Flooring 4 12-03-2010 07:47 PM
tile saw advice for 24" porcelain tiles diy'er on LI Tiling, ceramics, marble 12 10-11-2009 04:34 PM
porcelain tile questions gramps416 Flooring 4 01-04-2009 08:54 AM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 10:01 AM
