Best Way To Shine Tile Floors - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-28-2009, 01:18 AM   #1
best way to shine tile floors
What is the best way to make a tile floor really shine? I am going to be cleanning the basement of our church. The basement has only been in use for about 6 months. I tried to use Johnson Paste wax ( I used it in the Army) but it made the floor way to slick. I am at a loss I want it to look good but do not know how.
nogoode is offline   Reply With Quote
Old 03-28-2009, 06:30 AM   #2
ccarlisle's Avatar
Vinyl tile...asbestos tile...ceramic tile...? What???
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 03-28-2009, 09:55 AM   #3
ncl's ONE !
yesitsconcrete is offline   Reply With Quote
Old 03-28-2009, 11:33 PM   #4
I believe it is some cheap ceramic.
Old 03-28-2009, 11:36 PM   #5
What is the best kind of wax to use. I think I should use some kind of liquid but I do not know where to find any that doesn't say it is only for wood. Plus I probally will need more than a quart.
Old 03-29-2009, 05:24 AM   #6
remember what we used in the army, too,,, thankfully wax has come a long way since then call your local janitorial supply house - we like ncl's ONE, swing buffer, & white pad but you may have to strip 1st !
Old 03-29-2009, 06:47 AM   #7
You don't wax ceramic tile, that would make it dangerous. Just a drop of water and someone is on their backside.
Old 03-29-2009, 07:27 AM   #8
ccarlisle's Avatar
You know ceramic tile looks its best when there's nothing on it...no wax, no acrylics, no soap, no detergents. We have white ceramic in our kitchen and the way the lightning is at any time of the day, you can see everything on it.
We use Windex+Microfibre mop. We have two dogs... Windex and other glass cleaners are basically just alcohol and therefore evaporate. The dirt left behind gets picked up by the microfibre and within seconds, the floor is sparkling clean. And dry.
Anytime we put dishwashing liquid or Mr Clean or any other "floor" product, there are streaks and a stickiness that won't go away. It's because these products all have about 12% solids plus sticky detergents in them that doesn't evaporate and just sits there once the water has flashed off.
But now you may have to strip the floor of whatever is on there now, but that's a mop-and-bucket type operation, or a swing machine if you're in the trade. Get everything up and off and you'll have a slip resisitant surface to walk on. It may not be shiny like a mirror, tho.
Since tile is hard compared to waxes, it won't scratch or scuff as easily. There is no point, IMO, to put a topical coating on a tile.
Unless you dig maintenance...
Old 04-09-2009, 03:50 PM   #9
My mistake
The tile is a cheap stick on vinyal tile
Old 04-10-2009, 06:30 AM   #10
ccarlisle's Avatar
As I'm sure you know now, vinyl tiles are even less shiny when new than cheap ceramics and don't have the baked-on glazing ceramics do, neither are they are as hard. Compared to ceramic, they're soft and often made to absorb the repeated 'shocks' of footprints. Trouble is, also they're cheap cost-wise too and therefore have a huge market share. A good installation - just like ceramic - goes a long way in how the ultimate floor 'looks" once installed.
On the other hand their surface is tailor-made for an acrylic liquid wax, as opposed to a paste wax that goes on thicker. It's not a coincidence that many companies - for example: Armstrong - make both tile and 'wax' to make them shine (because normally the unwaxed tiles don't). Acrylic floor waxes are easy to make and therefore many people make them.
The paste wax you may have used in the Army was based on buffable softer waxes that shine a lot more, and given the availability of cheap labour, was buffed a lot...and therefore looked pretty good.
As for acrylics, NCL's s "ONE" is a good one, but there are several others out there; you're not going to find much new under the sun in acrylic wax technology... still, each manufacturer will have their own way of applying it. That may be just as important as the product itself, so just get hold of one and apply according to the instructions.
Like stone polishing, the ultimate shine on a surface has a lot to do with the underlying preparation done to the floor. So, stripping and cleaning the floor prior to waxing is a big part of how the waxing process goes. The word 'clarity' springs to mind, as a 'clear' shine has most to do with the preparation of the subsurface than it has to do with the final surface. All has to do with light reflection.
It"ll never look like a highly polished marble floor...but didn't cost that in the first place.
Old 04-14-2009, 06:13 AM   #11
i like marbles better than tiles . sometimes tiles get dangerous and accident prone.
Dana
Dana11 is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
tile over hardwood floors MnMan Flooring 1 07-30-2008 05:39 PM
Reasonable Quote on Tile Floors? kalaniwavo Flooring 1 08-17-2006 11:10 PM
