Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 02-04-2011, 07:54 AM   #1
best way to cut tile in place
If you could buy any tool-and-blade combination to cleanly trim away a half inch of 5/16 porcelain floor tile, in-place, around the perimeter of the toilet flange, after the tile has been laid and set with thinset, what would it be?
PVC toilet flange is not yet glued in place. Tiler did not leave a big enough hole for the flange to be set flush with the tile surface, and so the rim of the flange is sitting on the tile. Carefully trimming the tile in-place, if that's possible, is preferred to raising the toilet on a mat or hard insert.
diy888 is offline   Reply With Quote
Old 02-04-2011, 08:14 AM   #2
Super Moderator
A 4" angle grinder with a diamond clipper blade--(dry cutter) That's the standard method---
4" grinders are cheap--less than $20--if you get lucky--blades are cheap,too.
Get some wire brushes and use it to clean your grill--Just handy to have around the house--
Good luck--wear goggles--practice on a scrap first.---Have fun---Mike---
diy888 (02-04-2011)
Old 02-04-2011, 08:23 AM   #3
Super Moderator
I moved this to the tile section.
Old 02-04-2011, 08:30 AM   #4
A Little Of Everything
Mike's right, of course.
You're not going to get a nice, perfectly round circle that looks beautiful. You'll have lots of little 1/2" to 1" cuts. But don't worry, the toilet base covers that part anyway.
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
oh'mike (02-04-2011)
Old 02-04-2011, 01:51 PM   #5
I will just have to say proudly that I cut that dodecahedron myself.
Old 02-04-2011, 02:06 PM   #6
Originally Posted by diy888 View Post
i will just have to say proudly that i cut that dodecahedron myself.
big word alert!!!
Old 02-04-2011, 05:44 PM   #7
Super Moderator
DrHicks---He made that word up.
Old 02-04-2011, 06:06 PM   #8
Absolute the easiest method
Alcarte is offline   Reply With Quote
Old 02-04-2011, 07:25 PM   #9
nap
You talking to me?
nap's Avatar
I presume you meant: dodecagon. A dodecahedron is 3 dimensional shape (polyhedron) while a dodecagon is a 2 dimensional shape (polygon).
geesh. I wish I knew how many times I have to make corrections like this before people will learn.
Old 02-06-2011, 10:59 AM   #10
But what do you call a 3-D cylindrical shape with 12 faces? I suppose that would be a prism.
Old 02-07-2011, 12:08 PM   #11
Super Moderator
Uh,oh---word challenge for Nap----
Old 02-07-2011, 12:19 PM   #12
I haven't tried it, but maybe one of those "multi-tools" would do the job with a lot less mess.
Old 02-08-2011, 08:58 PM   #13
Dremel multi-max or similar. Although more expensive than a angle grinder, but maybe more useful.
Kiwi. is offline   Reply With Quote
Old 02-09-2011, 11:08 PM   #14
Since the cut is under the toilet, neatness isn't too important. A 4" angle grinder with a carbide cutting wheel does a good job. I hold an old wet grout sponge against the blade when I'm cutting in a house where neatness counts. It catches the dust great and no air-borne mess, but a little thrown dirty water.
A dremel with the very thin diamond wheel, the 1" or 1 and 1/4" size, cuts like a scalpel even on soft stone and slate.
Tile Pro is offline   Reply With Quote
Old 02-09-2011, 11:26 PM   #15
^ Great info. Thanks!
install outlet through existing tile? hoosadam Electrical 3 02-01-2011 01:47 PM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 05:39 PM
First tile job, what's the best place to start? dwalls32 Flooring 9 05-22-2010 11:25 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
