-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   best way to cut tile in place (http://www.diychatroom.com/f84/best-way-cut-tile-place-94499/)
diy888 02-04-2011 06:54 AM
If you could buy any tool-and-blade combination to cleanly trim away a half inch of 5/16 porcelain floor tile, in-place, around the perimeter of the toilet flange, after the tile has been laid and set with thinset, what would it be?
PVC toilet flange is not yet glued in place. Tiler did not leave a big enough hole for the flange to be set flush with the tile surface, and so the rim of the flange is sitting on the tile. Carefully trimming the tile in-place, if that's possible, is preferred to raising the toilet on a mat or hard insert.
oh'mike 02-04-2011 07:14 AM
A 4" angle grinder with a diamond clipper blade--(dry cutter) That's the standard method---
4" grinders are cheap--less than $20--if you get lucky--blades are cheap,too.
Get some wire brushes and use it to clean your grill--Just handy to have around the house--
Good luck--wear goggles--practice on a scrap first.---Have fun---Mike---
oh'mike 02-04-2011 07:23 AM
I moved this to the tile section.
DrHicks 02-04-2011 07:30 AM
Mike's right, of course.
You're not going to get a nice, perfectly round circle that looks beautiful. You'll have lots of little 1/2" to 1" cuts. But don't worry, the toilet base covers that part anyway.
diy888 02-04-2011 12:51 PM
I will just have to say proudly that I cut that dodecahedron myself.
DrHicks 02-04-2011 01:06 PM
Originally Posted by diy888 (Post 584611)
i will just have to say proudly that i cut that dodecahedron myself.
big word alert!!! :)
oh'mike 02-04-2011 04:44 PM
DrHicks---He made that word up.:laughing:
Alcarte 02-04-2011 05:06 PM
Absolute the easiest method
nap 02-04-2011 06:25 PM
I presume you meant: dodecagon. A dodecahedron is 3 dimensional shape (polyhedron) while a dodecagon is a 2 dimensional shape (polygon).
geesh. I wish I knew how many times I have to make corrections like this before people will learn. :hammer::wallbash::no:
diy888 02-06-2011 09:59 AM
1 Attachment(s)
But what do you call a 3-D cylindrical shape with 12 faces? I suppose that would be a prism.
oh'mike 02-07-2011 11:08 AM
Uh,oh---word challenge for Nap----
md2lgyk 02-07-2011 11:19 AM
I haven't tried it, but maybe one of those "multi-tools" would do the job with a lot less mess.
Kiwi. 02-08-2011 07:58 PM
Dremel multi-max or similar. Although more expensive than a angle grinder, but maybe more useful.
Tile Pro 02-09-2011 10:08 PM
Cutting tile.
Since the cut is under the toilet, neatness isn't too important. A 4" angle grinder with a carbide cutting wheel does a good job. I hold an old wet grout sponge against the blade when I'm cutting in a house where neatness counts. It catches the dust great and no air-borne mess, but a little thrown dirty water.
A dremel with the very thin diamond wheel, the 1" or 1 and 1/4" size, cuts like a scalpel even on soft stone and slate.
DrHicks 02-09-2011 10:26 PM
^ Great info. Thanks!
