Bathtub/ Shower Tiling - Tiling, ceramics, marble - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 11:58 PM   #31
Learning by Doing
Leah Frances's Avatar
Ok. I have a few things to say ( )
1. Kudos and to you, Buju for opening your ears/eyes/mind and taking in a some learning. I know from my own experiences DIYing how awful it is when you work SO hard to get something right, only to find out you have to do it ALL over again. You have some really great folks helping you out here, keep updating, asking questions, and post some more pics.
2. Good job Bud and Mike for walking Buju through this. Hopefully, it seems rewarding that Buju is paying attention and is trying to get it right despite all the 'help' he got from the guys at HD.
3. Bud, is your wife slipping something in your corn flakes? I kept waiting for your usual honest-to-a-fault-tell-it-like-it-is-dressingdown. I think you are mellowing. JK.
Nice job all around (and I realize that this whole post got a little girlie - but I'm a girl so )
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-17-2011, 12:20 AM   #32
Tileguy
Bud Cline's Avatar
Rewards Points: 558
download the 3rd pdf - unit installation and go to page 21,
H-m-m-m-m! I wonder where that is!
Do not install your wallboard OVER the flange. Install the wallboard TO the flange and caulk that juncture. DON'T try to fill the gap with silicone. Don't fill anything with silicone. Silicone sticks to everything but nothing sticks to silicone.
Still looking for that 3rd PDF.
XXX
Old 07-17-2011, 08:04 AM   #33
Sorry, didn't realize that the link was not going to get you there.
You have to go to: http://www.maaxcollection.com/Produi...8&persist=True
That is where you select Installation guides and only then the 3rd pdf.
Thanks for your patience..
On the other hand, I see the American Standard doing it similarly, as Maax. See page 2: http://www.americanstandard-us.com/a...nstall_884.pdf
Then there is the "middle of the road" approach, which recommends the same as Maax and AS, but with additional silicone behind the tiles. See this link from Oceania, page 9: http://www.oceaniabaths.com/fichiers...1049095749.pdf
And finally, Kohler's approach is different from all the above, as their flange seems to be really thin. See bottom of page 1: http://www.us.kohler.com/onlinecatal.../1084213_2.pdf
So, do I follow Maax's instructions? Bud seems to recommend that.
But I am a bit confused because the approach I was told to follow in this thread was to have the flange behind the CBU by running the CBU down to 1/8" from the tub. But that may have been for the add on flange or a thin flange. This integrated flange is 1/4" and CBU over the flange seems to be a no go.
If the CBU is to go to the tile, what happens to the 1/8" of play that you have to allow for bathtub movement?
The flange is not screwed on and if there is play isn't that going to go into the CBU? Maybe in the end that is OK. It's just a bit of play and the CBU should not give way/ break, right?
Finally, could I go with a CBU that has the same thickness as that of the flage, i.e. 1/4", instead of the 1/2" that I use so far? Given the size changes I will most likely not recover much of the old CBU anyway.
Is there ay risk of thee flange rubbing against the tile in any unpleasant way, especially that I wil put Regard over the flange?
My plan is to get 1/4" CBU, start it from the top of the flange, silicone that joint, Regard over the CBU, silicon joint, and flange, and then tile over to the flange, to the top of the tub. Finally seal the deal with siliconing the tile/tub joint.
Does this sound right? Should I use 1/2", even though it is more expensive and much harder to handle?
buju is offline   Reply With Quote
Old 07-17-2011, 08:33 AM   #34
Bathtub base
My bathtub comes preinstalled, with a base plywood and with 4 feet that have a very good rubber - very solid/ hard, but still rubber, so good for soundproofing.
Should I keep the feet? The tub is a bit to high and I am also paranoid about the drain area not being supported properly - no plywood underneath it, for easy access. BTW, am I too paranoid about the latter?
Thanks folks.
Old 07-17-2011, 11:14 AM   #35
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay that's enough for me.
Gotta go.
XXX
Old 07-17-2011, 11:28 AM   #36
Gotta go.
The older I get the better I was
Old 08-07-2012, 10:16 AM   #37
Old post, but thought I would share these observations for the next person reviewing them:
Bathtub/ shower tiling-tub.jpg
AlexDFox is offline   Reply With Quote
Old 08-07-2012, 07:03 PM   #38
Pro
JetSwet's Avatar
Rewards Points: 502
Would Like to see now pictures of how it's holding up?... Interesting ill say.
JetSwet is offline   Reply With Quote
Add shower plumbing to an existing bathtub Clock72 Plumbing 9 06-11-2011 04:23 PM
Converting Bathtub to Shower enkay18 Kitchen & Bath Remodeling 2 07-14-2010 02:05 PM
Tiling over greenboard outside shower area toocheaptohire Remodeling 4 04-10-2009 08:42 AM
need to convert a bathtub into a shower q5485 Plumbing 9 11-30-2008 09:39 PM
convert bathtub to shower argos Plumbing 10 02-19-2008 11:53 PM
