Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 01-19-2013, 06:26 PM   #31
Bathroom tile grout repair
Tile is set or installed either on a morter bed /concrete board such as wonder board or placed on plywood drywall or whatever this is listed in descending quality of install. 9 times out of 10 if the tile is surface bull nose it is not on a morter radius bull nose usually is. This is determined by looking at the edge pieces Surface has a small 1/8 curve and radius has about a 3/8 /1/2 curve. Use this guide to determine how2 bad the quality was or wasn't for starters Tile with a poor substrate around water will not last
Use non sanded grout if your spaces ore 1/8 or less use sanded if not
Regardless where the wall and deck change direction 90 degrees use flex calk in a tube. When done 3 days latter seal the grout with a good grout sealer
mr leak is offline   Reply With Quote
Old 01-19-2013, 06:32 PM   #32
Thanks...but that doesn't really answer my most recent question. The work is all done and its been 3 days so I'm at the sealing stage.
adgjqetuo is offline   Reply With Quote
Old 01-19-2013, 06:58 PM   #33
Super Moderator
The sealer can flush out some loose surface material--so a little dust on your finger is not a sign of failure---wait a day or two and wash the surface one more time to clean off and residue--
Old 01-19-2013, 11:15 PM   #34
Ok thanks - ill wait until tomorrow afternoon and give it a final sponge down. The bottle said 2-3 hours which is why I was questioning it. Even now over double the time the bottle has listed the grout still had a powderish feel to it. I expected it to feel more smooth almost like harden caulk.
I'll see what happens tomorrow. Maybe I spread it too thin or something, but I made sure all the grout was wet looking...twice.
Old 01-20-2013, 07:38 AM   #35
Super Moderator
Don't expect the sealer to do more than what it is designed to do--
All a sealer does is make the grout less likely to absorb dirt----that's it---
Water will still be able to go through the grout and reach the sub-straight---
Sealer can not water proof the grout.
Good luck--it sure looks better now----Mike-----
Old 01-20-2013, 09:11 AM   #36
Thanks for the info mike.
My other bathroom upstairs has the same tile with a dark gray grout. When I try to scuff it with my fingernail it appears to be harden and nothing scrapes off. Was a different coating used to make it do that?
Same goes for my master bathroom with the tub back splash (area that I didn't re-grout) and the shower stall tile which I didn't re-grout either.
Just curious.
Later on this afternoon I'm going to give the floor it's final washing and polishing with a dry towel. I can report back more the .
Old 01-20-2013, 09:14 AM   #37
Super Moderator
Could be one of many things----
To much water mixed with the grout---
to much water in the sponge when cleaning---
applying sealer before the grout was fully cured---
old stale grout-----
to many reasons to list---
wall out of plumb how do you tile it and have decent visuals. grout lines off by 1/4 papason Tiling, ceramics, marble 2 08-11-2012 03:46 PM
Replacing tile in bathroom floor (2x2 tile) Paul8434 Remodeling 1 09-05-2011 07:06 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 08:49 PM
