Bathroom Tile Grout Repair - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 08:29 PM   #16
Tileguy
JazMan's Avatar
Rewards Points: 388
Also, are any additives recommended or is just water ok to mix it with?
I don't know exactly which product you have. I asked whether it was Polyblend earlier. If it's from HD it should be Polyblend and is added to water.
Jaz
Old 01-14-2013, 08:47 PM   #17
Rewards Points: 398
Oops - sorry about that. Yes, it's Polyblend brand.
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 01-15-2013, 06:13 PM   #18
Rewards Points: 398
Ok so new grout is in place and I think it looks good! My only issue is I'm having trouble getting the cloudiness off the tile. I tried sponging it 7 hours later and it looks good until it dries and it gets cloudy again.
I'm going to do the floor tomorrow as well a the caulking around the tub.
Now for the bad news - one of the tub valves leaked and it put water through the floor and through my laundry room ceiling - the water came out in the light fixture which filled with water and smashed on the ground from the weight - the drywall was all mush too - the fun never ends...
Bathroom tile grout repair-image-3844293300.jpg   Bathroom tile grout repair-image-1277313721.jpg   Bathroom tile grout repair-image-1194376456.jpg   Bathroom tile grout repair-image-2951824972.jpg
Old 01-15-2013, 07:01 PM   #19
Tileguy
JazMan's Avatar
Rewards Points: 388
Ok, looks much better. The grout film needs to be wiped and buffed with dry cloths. There may still be old surface film like we saw in the old pics too. I suggest you let the grout cure a couple weeks, then clean with acidic tile and grout cleaner followed with grout sealer.
Jaz
Old 01-15-2013, 07:22 PM   #20
Rewards Points: 398
A couple weeks? I thought you could seal it after 3-4 days?
Also, what is the process for sealing? I bought the "surface guard" sealer.
Just spray in the grout lines let it sit and wipe clean?
Old 01-15-2013, 07:34 PM   #21
Tileguy
JazMan's Avatar
Rewards Points: 388
Read my reply again. I said 2 weeks because I recommend cleaning the entire room. You wanna clean it before you seal it.
Surface guard sealer, well, better than nothing if it's the cheapo yellow bottle, or pretty good if the green one. I like other brands but fine, use what you've got. Yes, apply, let it soak in a few minutes, then wipe off the tiles. It's the spray on type?
Jaz
Old 01-15-2013, 07:40 PM   #22
Rewards Points: 398
Ok so after a couple days use the acidic tile cleaner over the tiles and grout. I assume with a sponge and then wipe clean. Then let it sit a little while longer before sealing?
Yes, it's the spray type. Dark green bottle - I think it was around $25 for the 24 oz bottle.
Old 01-15-2013, 07:45 PM   #23
Tileguy
JazMan's Avatar
Rewards Points: 388
OK, be careful of the spray, not good to breathe. You need cross ventilation. So, are you gonna use a tile & grout cleaner or is it now clean? 2-3 days is good if no harsh cleaners will be used on fresh grout.
Jaz
Old 01-15-2013, 07:52 PM   #24
Rewards Points: 398
Sorry if I seem confused. The grout is fresh so I assumed it was clean that's why I didn't get why I needed cleaner. I sponged it down and it looked brand new.
Won't the acidic tile cleaner eat away at the fresh grout if its not sealed?
Old 01-15-2013, 08:15 PM   #25
Tileguy
JazMan's Avatar
Rewards Points: 388
Are you telling me you removed all the grout, every bit of it? If so why?
And....
Well sure, that's why I said to wait if you're gonna use an acid cleaner.
Jaz
Old 01-15-2013, 08:32 PM   #26
Rewards Points: 398
No, I just sponged down the tile which in turn lightly brushed the new grout too. The new grout is still there between the tiles the sponge didn't remove any.
I'm just going to finish the floor tomorrow using the same process as the tub, then seal the whole thing next weekend. Air out the room for a couple days after sealing and it should be finished.
Old 01-15-2013, 08:58 PM   #27
Tileguy
JazMan's Avatar
Rewards Points: 388
What does that mean? Did you apply grout over the old in some areas?
Jaz
Old 01-15-2013, 09:15 PM   #28
Rewards Points: 398
I used the diamond blade to grind the old grout down, cleaned it and applied the new grout on top and and after it set, lightly sponged off some of the leftover haze.
Old 01-15-2013, 09:21 PM   #29
Tileguy
JazMan's Avatar
Rewards Points: 388
OK, sounds good. Hopefully it'll work well until you can upgrade later. Be sure to come back so you can learn how tile in wet areas should be installed.
Jaz
Old 01-19-2013, 05:06 PM   #30
Rewards Points: 398
Hi,
How do you know if the floor is properly sealed? I sprayed the sealer onto the tile to where it was soaked. I then took a sponge and evenly spread the solution over all the grout ensuring it was all evenly wet and repeated throughout. I waited 3 hours and it appeared to be dry, but when I took my finger and rubbed the grout lightly you could still see some powder on my finger??
I just did a second coat hopefully that will help some. Should I do anything differently?
wall out of plumb how do you tile it and have decent visuals. grout lines off by 1/4 papason Tiling, ceramics, marble 2 08-11-2012 02:46 PM
Replacing tile in bathroom floor (2x2 tile) Paul8434 Remodeling 1 09-05-2011 06:06 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Grout question poolecw Flooring 11 10-29-2008 07:32 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 07:49 PM
