Bathroom Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-21-2010, 12:02 PM   #1
Bathroom tile
Using a Multi Max tool, can I remove grout and then remove the tiles and not destroy them, my house is old and I do not have replacement tiles. I am putting in a new shower valve and will have to remove some tile to get to the plumbing. The tile looks like they are on top of a "concrete" substance from what I can see after I removed the escutcheon plate on the existing valve.
ALIBEAU is offline   Reply With Quote
Old 02-21-2010, 01:59 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 340
It would take a miracle. I would do all the repairs from the other side. I doubt you'd have enough clearance to make the changes anyway. Cut a hole in the wall of the adjoining room and then patch it, or make a removable door/panel if it's in a closet.
Jaz
Old 02-21-2010, 02:44 PM   #3
Thanks Jazman, the other side of the bath wall is the vanity, so I would have to remove it to get behind the shower valve. I am going to have to go try to find some old tile that matches and go in through the bath side. I just don't see any other way.
Old 02-21-2010, 07:17 PM   #4
try finding some decorative tiles of the same size and see if you can weave them into the wall around the fixture
The older I get the better I was
Old 03-02-2010, 07:02 AM   #5
Tool Cop
Originally Posted by ALIBEAU View Post
Using a Multi tool, can I remove grout and then remove the tiles and not destroy them, my house is old and I do not have replacement tiles. I am putting in a new shower valve and will have to remove some tile to get to the plumbing. The tile looks like they are on top of a "concrete" substance from what I can see after I removed the escutcheon plate on the existing valve.
It will take some patience, but it can be done. Just be really careful.
TrafficCopSmith is offline   Reply With Quote
Bathroom tile color coordination cellophane Interior Decorating 5 01-30-2011 11:47 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Bathroom Renovation-To Tile or not to tile jte1130 Remodeling 7 04-14-2009 10:39 AM
Bathroom Vanity against a pre-existing wall of tile dcormann General DIY Discussions 2 03-24-2009 01:05 PM
Help! Botched bathroom tile job steamed17 Remodeling 13 05-01-2008 09:40 PM
