Bathroom Reno - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-22-2012, 09:37 PM   #1
Rochsolid's Avatar
Bathroom reno
Hey guys, I'm starting a bathroom Reno in a few weeks and had a question about tiling. Should I always back butter them? Thanks
Rochsolid is offline   Reply With Quote
Old 11-23-2012, 08:32 AM   #2
joed's Avatar
Rewards Points: 12,016
Always? No. Sometimes? Yes
Old 11-23-2012, 09:03 AM   #3
DIY staff
Rewards Points: 7,174
Need more info----It depends on the situation----
Old 11-23-2012, 09:15 AM   #4
Rewards Points: 13,300
Please, please ask all the questions you feel you need to before doing anything.
Look at some of the older post in this area and you'll see hundreds where there already into to it and have done it completly wrong and now want to know how to "fix" it.
Old 11-23-2012, 09:39 AM   #5
Rochsolid's Avatar
Bathtub surround, is where I will be laying the tile.
Old 11-23-2012, 01:02 PM   #6
DIY staff
Tile comes in many sizes---and different materials----and is set with different thinsets----those are the factors that determine if back buttering is needed.
Answer those questions and you will get a real answer----
Old 11-23-2012, 01:09 PM   #7
Rochsolid's Avatar
Ceramic, 12" by 12" on concrete backer board with mortar
Old 11-23-2012, 02:43 PM   #8
DIY staff
12x12----very good idea you back butter the larger tiles---use a good quality modified thinset---
Old 11-23-2012, 02:46 PM   #9
Rochsolid's Avatar
Thanks a lot Mike, I really appreciate it
Old 12-04-2012, 08:35 PM   #10
Rewards Points: 4,792
As a general rule, if the back of the tile (regardless of size) has a waffle shape, or just any sizable nooks and crannies, then back butter it. If the tile is large (starting at about 12"), back butter it even if it is smooth. Remember when you trowel your thinset to leave the furrows all in the same direction. Otherwise when you set the tile it will be difficult to avoid large air pockets underneath, because that would defeat the purpose of buttering anyway. (The furrows in the same direction help channel the air out as you lay the tile down.)
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Rochsolid (12-07-2012)
Bathroom flooring reno Mark Harvey Flooring 1 06-10-2012 10:03 PM
Remodel vs. repair bathroom slab on grade JCTeacher Plumbing 3 04-15-2012 06:54 AM
Surprise bathroom reno for my wife wedge22 Project Showcase 21 09-10-2009 02:59 PM
Making Walls Plumb in Bathroom Reno cbj8585 Building & Construction 4 05-20-2009 04:48 PM
Bathroom reno mrrenovater General DIY Discussions 2 05-11-2009 07:01 AM
