Bathroom - Install Tile Floor - Leave Existing Cove Base - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 02:12 PM   #1
Bathroom - Install tile floor - leave existing cove base
I'm planing on installing a ceramic tile floor in my bathroom (previously just vinyl over plywood). There is currently a ceramic cove base. If I install average thickness tile on the floor there will likely be a bit of a gap where the floor meets the base of the walls. How have people dealt with this in the past?
jpfulton248 is offline   Reply With Quote
Old 05-17-2013, 02:37 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Did you take the vinyl and plywood out?
Post pic of the gap.
JetSwet is offline   Reply With Quote
Old 05-17-2013, 02:51 PM   #3
Have not taken vinyl or plywood out. The vinyl is coming up in a few places or even missing in other places. The gap doesn't really exist yet because there is no ceramic tile down. I had this issue at a previous house where I paid a guy to do my bathroom. His solution is to pretend it wasn't a problem. I'll use a tile I have sitting around to try to demonstrate the issue I'll be facing and take a pic.
In the meantime, here's an illustration.Bathroom - Install tile floor - leave existing cove base-untitled-1.jpg
Old 05-17-2013, 03:04 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
Usally no one who retiles there bath wants to keep the base tiles.
When you loose the vinyl and plywood which is a must. What Will you have for plywood subfloor? What are your plans for substrate? Like cement board or ditra mat for tile bond?
If you have good joists, span and spacing 3/4" ply will be ok to work with. I personally like more for ceramic. but that's me.
1/4" plywood isn't recommended under cement board.
Old 05-17-2013, 03:35 PM   #5
The base tile transitions into the wall tile... and we don't really feel the need to re-tile the walls. They look pretty good. So basically the base stays. The whole substrate/subfloor question was a follow question but I can see how that would affect the severity of the "gap". I don't have a plan for substrate yet but was about to start researching. Sounds like I need to rip up the plywood then put down something like ditra mat or cement board? Just to clarify, I definitely can't set tile right on the existing plywood, right? I'll need to put down either ditra mat or cement board?
Old 05-17-2013, 04:57 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
You could tile over a sanded or exposure ply with modified thinset but there will be no garenty that it will last and won't be water proof.
1/4" cement board or ditra mat which is thinner
Old 05-17-2013, 10:52 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 388
Fulton,
Are you positive there is just plywood directly under the present vinyl? How long ago was this bathroom built? I'm thinking it may not be as you think.
Got pics?
Jaz
bathroom remodel complications megancn Building & Construction 6 07-24-2012 04:38 PM
install outlet through existing tile? hoosadam Electrical 3 02-01-2011 12:47 PM
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 03:46 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
remove/replace tile over mud base jfm617 Flooring 1 07-07-2007 06:38 AM
