Bathroom Floor & Shower Waterproofing Questions - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 12:39 PM   #1
Bathroom floor & shower waterproofing questions
Hello!
I am preparing to tile a bathroom and had a few questions to ensure this is done correctly. I've done some reading, including this (http://www.diychatroom.com/blogs/con...wer-walls-152/) but am still unclear on a few items.
1. First, the bathroom floor. I'm doing electric in floor heat and the bathroom is in a basement which has a concrete floor. Is there anything that needs to be done to the concrete prior to installing the in-floor heat and then the tile?
2. For the shower walls I'm a bit confused... the link above mentions "this is where the liquid waterproofing products can also come into play as well as the sheet membranes if you should choose not to use a waterproof wallboard." Does this mean that the liquid waterproofing CAN be used with a non-waterproof wallboard? Or, if you use a non-waterproof wallboard do you need to install the membrane and not use the liquid?
Any advice is appreciated... thanks!
hotbread is offline   Reply With Quote
Questions about my Bathroom Storage Project jdauriemma Kitchen & Bath Remodeling 0 07-14-2010 08:41 PM
Basement Bathroom Rough-In Questions jmmahon1224 Plumbing 0 07-13-2010 12:48 PM
Questions on waterproofing tile walls for shower with floor pan. HautingLu Tiling, ceramics, marble 11 09-18-2009 11:12 AM
Basement Bathroom Rough-in questions Bmbeeson Plumbing 16 12-29-2007 01:41 AM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
