Bathroom Floor Has Crown (high Spot) In Center Of Floor, Want To Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-02-2011, 11:18 AM   #1
Bathroom floor has crown (high spot) in center of floor, want to tile
Hey guys,
I had some structural issues in a house I bought and the house had to have new joists sistered onto 8 of the exisiting joists along with a beam installed to support it due to what appeared to be water damage. The contractor's said they got the floor the best that they could with the room they had to work with in placing the beam in the basement (basement is finished).
I laid hardibacker down in my bathroom and it became apparent that there was a crown in the center of the floor that ran the whole length of the bathroom. The floor then has a slight slope on each side of the crown (pictures included). I would say from the highest spot, to the lowest spot on the floor there is maybe half and inch of slope (just a guess, used a 4ft level to gauge it).
Is this something I will have enough adjustment with with my thinset when I lay the tile to level it out? Use a 3/8" notched trowel to get more adjustment? I was going to lay 12x12 porcelain tile most likely. Should I scrap that idea and go with something more forgiving like a smaller 6x6"? Is it possible to pour self leveling concrete over the hardibacker?
Bathroom floor has crown (high spot) in center of floor, want to tile-slope.jpg   Bathroom floor has crown (high spot) in center of floor, want to tile-pic-0378.jpg   Bathroom floor has crown (high spot) in center of floor, want to tile-pic-0377.jpg
tunabreath is offline   Reply With Quote
Old 09-02-2011, 11:48 AM   #2
A Little Of Everything
Rewards Points: 1,362
I don't think self-leveling concrete is the way to go - though I could be mistaken. I've only used it on a concrete floor.
The answer kind of depends on how much of a perfectionist you are. I believe that, with your Thinset, you can build up at least 1/4" in the sides, which leaves you with a slope of about 1/4" over 18". Can you live with that?
On a personal preference note, I think that's a pretty small space to be using 12x12 tiles. Big tiles tend to make a small area look even smaller, especially if they're not laid at a 45 degree angle.
DrHicks is offline   Reply With Quote
Old 09-02-2011, 12:20 PM   #3
I wasn't sure about the SLC either, thought it was mainly designed for basement floors and concrete slabs.
I thought it worked vise versa...big tiles make an area look bigger? I will probably go with a 6x6 tile then since it will probably be more forgiving with the crown/slope. I figured that with a 3/8" notched trowel it would give me more play while still giving me good adhesion.
Old 09-02-2011, 03:52 PM   #4
Hold on just awhile though. There are some professionals here, and I'm sure they'll be along to give you better opinions than just mine.
It also occurs to me... Is your toilet flange set for the increased height of tile?
Old 09-02-2011, 03:53 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not true. SLC's can be used anywhere.
According to all of the decorators I do work for they insist larger tiles make a room look larger.
Six inch tile would be happy to follow the slope... but so would twelve inch tiles if you place a grout joint at the crown of the room.
The problem with your theory of using thinset is that thinset is designed to be gauged by the size trowel you use. To attempt to build-up individual tiles in this fashion will only result in a small disaster. Thinset is notorious for shrinking and when it shrinks it will take the tile with it. This will result in some serious lippage where the most thinset-fill is used.
The room isn't that big. SLC would fix the entire problem in short order.
Here's a little more information that should help you. There are two parts to the blog.
http://www.diychatroom.com/blogs/ins...t-one-two-177/
XXX
The Following 4 Users Say Thank You to Bud Cline For This Useful Post:
DrHicks (09-02-2011), epson (09-28-2011), oh'mike (09-02-2011), tunabreath (09-02-2011)
Old 09-02-2011, 05:20 PM   #6
Thanks, Bud. So SLC IS what you recommend for this case? How many sq ft does a bag typically cover? I read your blog, going to read it over a couple more times. Use sill gasket along the whole perimeter of the walls, including the tub I assume?
The toilet flange hasn't been glued into the waste pipe yet. Which brings me to my NEXT question. Flange on top of tile, or flange on top of backer board??
Old 09-03-2011, 12:40 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
To plane that floor I would use SLC, yes.
Sill seal is used to create an expansion gap and it is necessary everywhere in my opinion.
The toilet flange can sit atop the tile or atop the tilebacker, doesn't matter.
XXX
Old 09-03-2011, 12:44 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Whoops - forgot!
One fifty pound bag of SLC typically covers fifty square feet of floor space 1/8" thick. Didn't I put that in the Blog? I don't remember.
XXX
Old 09-03-2011, 01:04 PM   #9
m1951mm's Avatar
Hey Bud, I am about to do my bathroom floor and the correct height of the flange can be an issue. I have used flange extenders to get the flange to be the same height as the finished tile, is there a better option?? or should I say easier?? It is not that hard to screw in the extender, but what about on a concrete slab??? I know you are the MAN for tile, and that is why I ask.
Speaking of flange extenders, if you add one to the top of the existing should a bead of silicone or (???????????) be added to make sure the new potty does not seep??
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Old 09-03-2011, 01:11 PM   #10
Ok going to give this a shot Monday or Tuesday. One last question since the blog didn't cover this. Do I only use the SLC to fill in the low spot and let it level itself with the high spot? OR do I need to pour enough SLC to cover the WHOLE floor?
Old 09-03-2011, 02:38 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If the crown is consistent from one end to the other I would plan to pour SLC to first one side of the crown and then the other side of the crown. I would figure enough product to cover the entire room. The problem with this room is the SLC won't feather on its own to blend it to the crown leaving the crown uncovered so to speak. And in addition you have to be able to back your way out of the room as you pour.
Difficult to explain (maybe) without being there.
What are the measurements of the room? It appears the measurement you don't show is just under 96" !!! Is that correct?
XXX
Old 09-03-2011, 03:21 PM   #12
m1951mm's Avatar
Here is a repost hoping that Bud or???? will address the issue of the flange. Kinda important in a bathroom.
Mickey
Old 09-03-2011, 03:33 PM   #13
Sorry the measurements I put on that diagram are wrong.
The room is 6ft x 11ft.
That top measurement on the diagram should be 6ft, not 5ft.
Old 09-03-2011, 03:50 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The room is 6ft x 11ft. That top measurement on the diagram should be 6ft, not 5ft.
Okay somethings still being left out. There must be a closet or blank wall or something on the left as you enter.
Tubs are typically 60", toilet cubby holes are typically 30" to 36". Your information leaves 36" unaccounted for on the left side.
Then on the right side...is there a vanity and is it in place or will it be installed later?
I come up with fifty square feet of floor space if you don't take out for a vanity.
XXX
Old 09-03-2011, 04:29 PM   #15
Yes sorry there is a blank wall on the left directly as you enter the room.
The circle in the top left of the diagram is the waste pipe, directly across from it on the other side of the room is where the vanity will be located. 36" vanity, but it will be installed after the floor is laid.
So if I pour the SLC on both sides of the crown, working my way out of the room, and the crown is left exposed, is that OK to tile over? Or are you saying that the SLC will not feather itself enough in the transition to the crown? So just plan on coating the whole floor in SLC, covering the crown?
Bud, thanks so much for answering these questions. No one I know has used this stuff before so it is nice to get some answers. Much appreciated!
Installing a Toilet on a new tile bathroom floor saltrl Introductions 2 06-21-2011 09:12 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Bathroom Floor - Tile - floor Height - Flange DoItYourSelfer5 Flooring 2 12-15-2008 07:18 PM
Ceramic tile in bathroom ClnlBrahm Remodeling 11 09-21-2008 10:09 PM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 08:03 PM
