Bathroom Ceilings - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 06:14 PM   #1
THY
bathroom ceilings
how should i install large ceramic porcelain tiles on ceiling
THY is offline   Reply With Quote
Old 02-01-2011, 06:17 PM   #2
THY
Old 02-01-2011, 08:28 PM   #3
I did it once and used my zip poles to hold the tile in the thinset while it dried.The ceiling was backerboarded after the drywall was removed. I guess any kind of dead man system could work.
FlooringDude is offline   Reply With Quote
Old 02-02-2011, 09:05 AM   #4
woodman58's Avatar
I have done 12 x 12 tile on the ceiling. I would use wall mastic with a 3/8" trowel. With 12 x 12 tile I did not have to use any thing to hold them up. Make sure and keep an eye on them to make sure they don't sage. If you are using a larger tile or you want to make sure they don't sage or drop you can cut a 2x4 the width of the ceiling and another one a little bit longer than the hight from the floor to the ceiling 2x4 and wedge the ceiling 2x4 to hold the tile. Do not press to tight. Just enough to put the tile into the mastic.
woodman58 is offline   Reply With Quote
Old 02-02-2011, 09:23 AM   #5
DIY staff
Rewards Points: 7,174
I've had no difficulty with 12x12 using 2 part modified thinset---Kerabond and Keralastic--
no temporary support needed----Mike---
Old 02-02-2011, 12:27 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 422
Come on guys............you don't need anything to hold tiles to a ceiling. You guys wear hard-hats when doing ceilings? They'll stick better than to a wall. Tile might slide on walls if not supported.
Mastic on a shower ceiling over tile backer board? Why would you do that? What did you use on the walls?
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
oh'mike (02-02-2011)
Old 02-02-2011, 01:21 PM   #7
woodman58's Avatar
It was over contracter installed green board with epoxy grout
Old 02-02-2011, 05:46 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 422
Those "contractors", can't trust them to do the right thing.
OK so, mastic on the walls with epoxy grout. Any waterproofing used?
Jaz
Old 02-02-2011, 08:09 PM   #9
...probably not. I'm sure it's the way the contractor has always done it though. I can't believe that there are still people who use green board and mastic in showers.
Old 02-02-2011, 08:10 PM   #10
btw I'm sure a well mixed thinset will hold tile to a ceiling but without experience I would suggest using a dead man to hold the tile up there.
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
gutting bathroom debiasio Remodeling 30 02-17-2011 02:32 PM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 08:00 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 12:17 AM
