Ball-park $ For Mud Bed .... - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-08-2009, 01:27 PM   #16
I probably wouldn't do just the base receptor.
This might just be my main problem - hiring a contractor to just do the base.
I appreciate your insight and help.
SandyK is offline   Reply With Quote
Old 03-17-2009, 10:13 PM   #17
Sandy,
I've called tile stores and gotten prices of between $250 and $600 for a custom built shower pan ready for tile (33"x60"). This is in Northwest Indiana.
Quickdraw is offline   Reply With Quote
Old 03-17-2009, 11:56 PM   #18
Thanks Quickdraw. I figured it was somewhere in that range.
Old 03-19-2009, 02:50 PM   #19
And I'm going with the $250 guy... he doesn't have a store front as he is basically a flooring/tile installer. He seems pretty good and answered questions I had about building the stall & curb.
Old 04-09-2009, 09:22 AM   #20
toocheaptohire's Avatar
Sandy - I had the same situation it sounds like you're in (ripped out 1 piece fiberglass shower, redo with tiled walls and floors) and I ended up putting in the mud bed myself using the Goof Proof / Quick Pitch system (I think Mark E is the mfr, just google it). I was recommended this by our MN version of Century Tile (I used to live in Chicago). Had I discovered this forum earlier, I might have tried the Schulter / Kerdi system a lot of experienced folks here seem to like (and will probably try it on the master bath reno teed up for next year), but I'm happy with the results. I was very hesitant to make my own pan because I didn't think I could get the slope right, but this Goof Proof system somes with plastic "spokes" you lay in the shower base and use to shape the concrete slope (spokes are higher at the perimeter, slope down towards the drain). I also bought a $5 DVD that walked me through the whole thing. Easiest part of it was the "mud" - specified a very dry mud mix so it wasn't nearly as goopy as thinset/mortar mud for when you get to the tile part. Cost for mud, kit (pan "spokes" and curb forms), liner, etc was $135 which is less than half of Schulter (and another $5 for a mud pan from Home Depot) and I did it over 2 days (only an hour or so each day). Not nearly as scary as I thought it would be, and my husband now brags to his buddies that his wife put in a mud shower pan. Anyway, just my 2 cents, but since it sounds like you're already pretty experienced with the cement board and tile installation, I'd encourage you to give this a try (or at least think about it). Good luck.
toocheaptohire is offline   Reply With Quote
Old 04-13-2009, 02:21 PM   #21
Chicago, IL
Michael Thomas's Avatar
Sandy,
Go to http://www.johnbridge.com/vbulletin/....php?forumid=1 for more than you could possibly want to know about building you own shower.
I don't sell, install or service tile installations - I just get to inspect a lot of then - so I have no financial bias toward any of the various shower pan systems, however based on my experience with both homeowner and professional installs I would strongly recommend that you at least consider a Schluter-KERDI or similar system no matter who is installing it.
Home Inspection: "A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources."
Michael Thomas is offline   Reply With Quote
Old 05-10-2009, 12:59 PM   #22
I'm in D.C., and doing just the base you describe, including the necessary waterproofing with no plumbing or flooring adjustments, etc., would probably average around $500 in labor. Materials would be around $100.
dhoult is offline   Reply With Quote
Is this gas ball valve safe? nutlog Plumbing 17 12-23-2008 02:40 PM
Delta shower lever ball questions.. topspin Plumbing 1 08-15-2008 09:57 AM
Ball and Socket Joint Question lateralan Carpentry 9 04-25-2008 10:12 AM
Control Arm - Self locking nut spins ball joint dkbaum Automotive Repairs 4 02-24-2008 12:56 PM
Got a price for my roof... in the ball park? awayne Roofing/Siding 6 06-06-2006 09:32 AM
