Bad Tile Job - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 11:05 AM   #1
Still Learning
Bad tile job
Hi all, i have ceramic tiles in the kitchen and bathrooms. The grout is coming apart all over the place. Is this because he did not put plywood down on top of the hardwood before setting the tile? I dont know if that is the case, so i wanted to ask you guys what would cause this to happen. Thanks for your time.
thehvacguy is offline   Reply With Quote
Old 03-22-2011, 11:46 AM   #2
DIY staff
Rewards Points: 7,174
That's typical failure caused by loose tiles---Lift an air vent--I'll bet the tile is set over plywood--
tile must(IMO) be installed over a cement backer or the Ditra type membrane.
Post your floor joist length--spacing--and size--one of us will check the span--However,those tiles are loose,not cracked----installation error-----Mike---
Old 03-22-2011, 01:26 PM   #3
Still Learning
I forgot to mention that the kitchen tiles cracked under my feet when we carried in the refrigerator. I will be back with the specs for the floor joists thanks
Old 03-22-2011, 01:56 PM   #4
Still Learning
The floor joists are 2 by 12, 16 on center, with supports every 6 feet.
Old 03-22-2011, 07:53 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
In a word!
YUP!
You cannot install any ceramic tile directly to hardwood or slat-wood substrates. But I guess you now know that!
XXX
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
