Backsplash Tiling - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-18-2012, 09:30 AM   #1
Rewards Points: 97
Backsplash tiling
Ok, I am in the middle of a kitchen remodel. I removed the backsplash yesterday in preparation for my new counters next week.
On one side of the kitchen the plaster walls did not hold up well at all. Big chunks missing(it is a very old home)
I plan on doing the backsplash after the countertops but need to know how to prepare this wall for tiling
Will the thinset help level things out.
My initial thought was to install the countertop and then use some 1/4 inch backer board over the screwed up surface to give me a nice surface to install to
Any suggestions???
As you can see in the pictures my first attempt was usuing joint compound to fix this, but some of the uneveness was just too much
Backsplash tiling-imag0210.jpg   Backsplash tiling-imag0211.jpg   Backsplash tiling-imag0212.jpg
BigRedFan is offline   Reply With Quote
Old 11-18-2012, 09:58 AM   #2
DIY staff
Rewards Points: 7,174
Three choices-----
Shim coat that----it can be done---
Remove the plaster and replace with drywall---some furring will be needed to match the thickness
Use large tiles and let the thinset fill the voids--this is a bad idea because the tiles will want to slide out of position,
Overlaying that this more material is not an option---- cabinets will be buried--window trim--counter reveal--
Old 11-18-2012, 10:00 AM   #3
Rewards Points: 97
What would you recommend using for the skim coat?
Old 11-18-2012, 10:05 AM   #4
Rewards Points: 13,220
Looks like you tryed using to narrow a knife to skim coat it.
Now your going to have to sand with a sanding pad to get rid of the high places, vacuum it off and do it again with a 6" wide knife with drywall compound. Thinning it slightly with a few drops of water will help make it flow better.
Old 11-18-2012, 10:06 AM   #5
DIY staff
Powdered drywall compound---easy sand 45----the 45 is the set time----comes in 5-20-45 and 90 minute--
use several thin coats---it's easiest that way---I use 20 minute---but a novice can find the fast setting stuff frustrating---you may end up spending to much time cleaning tools with the 20---
Old 11-18-2012, 10:51 PM   #6
Rewards Points: 940
And why aren't we just stripping the wall and re-doing with tilebacker?
If you are getting new countertops, then remove them and the top cabinets. Rip out the plaster & lathe, do your electrical & plumbing work as necessary, and replace with tilebacker. Re-hang the upper cabs and tile away on the backsplash.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
oh'mike (11-19-2012)
Old 11-19-2012, 09:44 AM   #7
Rewards Points: 97
Been using easy sand 45...so far have done 2 coats and it looks a million times better.
Im thinking one more coat should do the trick
Old 11-19-2012, 09:57 AM   #8
DIY staff
Not to pretty---but if it's flat you are good to go---take your blade and scrape off ridges and high spots and I think you will be fine----
Old 11-19-2012, 10:01 AM   #9
Rewards Points: 97
I plan on sanding it down real nice too...Still a night and day improvement and will make it easier to set tile too
Old 11-19-2012, 10:18 AM   #10
DIY staff
You mentioned one more coat---you be the judge on that----the main thing is a flat surface---
It takes a lot of experience to get good and fast with drywall mud---Your results will give you a good surface for tile----pretty doesn't matter---
Old 11-19-2012, 10:45 AM   #11
Rewards Points: 97
I plan on doing one more coat because there are still a few areas that need to be leveled out.
I am not trying to make it look super pretty but it may be a month before it gets tile so I wouldnt mind it looking nice
The Following User Says Thank You to BigRedFan For This Useful Post:
Old 11-20-2012, 05:16 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Don't expect any tile adhesive to bond to all of that (gypsum) patchwork without first priming the patched surface.
XXX
Old 12-10-2012, 05:22 PM   #13
Rewards Points: 97
Ok I am finally about to dive in and take care of the backsplash. The final step of our kitchen renovation.
Is it necessary to prime the compound I put down before putting the mortar down?
Also should I use the premixed mortar or mix it myself??
Old 12-10-2012, 07:13 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
XXX
Old 12-11-2012, 02:28 PM   #15
Rewards Points: 97
Ok Priming it tonight.;
What sort of tile adhesive should I use for a glass mosaic tile? Should I mix it myself or get the premixed stuff
How to prepare the wall for tiling backsplash? lts Tiling, ceramics, marble 2 07-02-2012 10:31 AM
Tiling My Kitchen Backsplash Over Existing Paint - Any Special Prep? WoodySoCo General DIY Discussions 16 07-19-2011 09:19 AM
tiling over laminate/formica backsplash doqfleed Tiling, ceramics, marble 4 06-15-2010 12:25 AM
Tiling / backsplash question Mark755 Kitchen & Bath Remodeling 4 02-26-2010 02:01 PM
Tiling kitchen backsplash deeaa Building & Construction 6 07-17-2008 09:44 PM
