Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 01-14-2012, 04:38 PM   #1
Backsplash Installation - Outlets
I am planning to put a ceramic backsplash in our kitchen this week. I am wondering how people get the outlets "flush" with the backsplash. The "wall" will be extended out 1/4-1/2 inch so how do people get the outlets right?
Any help would be much appreciated!
mattroessner is offline   Reply With Quote
Old 01-14-2012, 04:49 PM   #2
A Little Of Everything
Outlet box extenders are pretty common.
DrHicks is offline   Reply With Quote
Old 01-14-2012, 05:53 PM   #3
MarginallyQualified
Longer screws for the devices are usually enough if the rough in is done right.
TarheelTerp is online now   Reply With Quote
Old 01-14-2012, 06:13 PM   #4
I cut my tile small enough if you will, that the metal "fingers" on the top and bottom of the outlest rested on the tile...worked out just fine for me...
________________
check out my Man Blog
jasonreck71 is offline   Reply With Quote
Old 01-14-2012, 06:34 PM   #5
________________
That's certainly ideal.
Old 01-14-2012, 08:58 PM   #6
Ironlight's Avatar
Definitely tile up as close to the box as possible...it gives you more options in terms of cover plates and makes installation easier. If you need longer screws they are 6-32.
Ironlight is offline   Reply With Quote
Old 01-14-2012, 10:12 PM   #7
Thanks for the suggestions guys! I appreciate the help.
Old 01-14-2012, 11:51 PM   #8
install them like this and you shouldn't have a problem
epson is offline   Reply With Quote
Tags
backsplash, ceramic, tile
Installing GFCI outlets in old home surdules Electrical 2 10-20-2010 11:22 AM
Tricky Backsplash installation katliz Building & Construction 2 03-29-2009 04:49 PM
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 02:08 PM
downstream of GFCI outlets amakarevic Electrical 11 12-25-2008 02:13 PM
Attaching a backsplash to wall/countertop DanBress Carpentry 3 09-10-2008 09:09 PM
