Backsplash Application - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-12-2014, 04:19 PM   #1
Rewards Points: 528
backsplash application
Is it ok when installing kitchen backsplash tile-ceramic- to painted drywall to use the adhesive right to the clean drywall or is a backer board required?
Also is thinset always better or can i use the premixed adhesive?
hidden1 is offline   Reply With Quote
Old 01-12-2014, 07:21 PM   #2
DIY staff
Rewards Points: 7,174
You will be fine going over a painted drywall surface---be sure it is clean and if it's glossy paint --scuff sand it --
Premixed mastic is fine for a back splash----as long as the tiles are not to large--mastic needs air to dry--
There is no advantage to using a backer board --thinset is fine if you wish--once again,no big advantage over mastic except for cost---
JazMan (01-13-2014)
Remove laminate backsplash georgioltd Remodeling 4 10-17-2012 06:56 AM
refinishing a counter and adding a backsplash Lilion Kitchen & Bath Remodeling 6 08-18-2012 12:22 PM
tiling over laminate/formica backsplash doqfleed Tiling, ceramics, marble 4 06-14-2010 11:25 PM
Tiling / backsplash question Mark755 Kitchen & Bath Remodeling 4 02-26-2010 01:01 PM
Attaching a backsplash to wall/countertop DanBress Carpentry 3 09-10-2008 08:09 PM
