-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   backsplash application (http://www.diychatroom.com/f84/backsplash-application-193883/)
hidden1 01-12-2014 04:19 PM
152 Attachment(s)
Is it ok when installing kitchen backsplash tile-ceramic- to painted drywall to use the adhesive right to the clean drywall or is a backer board required?
Also is thinset always better or can i use the premixed adhesive?
oh'mike 01-12-2014 07:21 PM
You will be fine going over a painted drywall surface---be sure it is clean and if it's glossy paint --scuff sand it --
Premixed mastic is fine for a back splash----as long as the tiles are not to large--mastic needs air to dry--
There is no advantage to using a backer board --thinset is fine if you wish--once again,no big advantage over mastic except for cost---
