Backer Board Shenanigans - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-27-2013, 02:56 AM   #1
Renovating My Land Yacht
Rewards Points: 616
Backer board shenanigans
We have a cast iron tub in one of the baths and I am not hoofing it out of the house so we are going to do a tile surround. There was one of those plastic ones there before but that had to go when we gutted.
I can never remember which way is right with respect to the backer board and the tub lip. Is it version A where the backer board goes over the lip or B where it ends flush with the lip. I have attached two images to help explain when I am asking.
Muchos thanks.
Robyn
forcedreno2012 is offline   Reply With Quote
Old 04-27-2013, 04:11 PM   #2
jproffer's Avatar
Rewards Points: 710
I've always put both down over the flange (like A), but I think either way you show would be fine.
BTW, nice drawings
jproffer is offline   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
forcedreno2012 (04-28-2013)
Old 04-28-2013, 01:11 AM   #3
Rewards Points: 616
Thanks JP....as always a picture is worth a thousand words
Old 04-28-2013, 06:24 AM   #4
DIY staff
Rewards Points: 7,174
I stop the board above the flange and fill the void with thinset as I tile--or before if the surface of the board is to be waterproofed---( second drawing)
Old 04-28-2013, 08:27 AM   #5
Rewards Points: 528
You use thinset on the tub lip?
framer52 is offline   Reply With Quote
Old 04-28-2013, 08:33 AM   #6
DIY staff
Yes,---Mix a small batch on the thick side---and fill that void---then waterproof it when it's set---
forcedreno2012 (05-05-2013)
Old 05-05-2013, 10:36 AM   #7
Rewards Points: 616
Mike, If you fill it with thinset how do you keep the line straight - do you use some type of ledger or just straighten the edge with the waterproofing? I can envision doing it this way and having a wavy line at the bottom.
Robyn
Old 05-05-2013, 09:12 PM   #8
Rewards Points: 950
The problem with A is that you have to fur out the whole wall.
Couldn't understand your last post about keeping it straight. Did you mean up and down or in/out?
Generally, I end up cutting the bottom course of tile to fit. The tub is rarely level. Let's say it is 1/2" out of level, and you are using 6" tile. So you cut some tile to 5 1/2 and some you can probably use at 6". Then you are level for the second course.
And you lay the second course first on a ledger.
cleveman is offline   Reply With Quote
Old 05-05-2013, 09:19 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,812
I like the little duck.....
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 05-05-2013, 09:47 PM   #10
Rewards Points: 616
Clever, I was referring about the backer board being level per se with the tub lip and then Mike talked about mudding below the backer board and then waterproofing. I was concerned with if I mud below the board where it meets the tub, how do you keep the mud straight on that edge if there is nothing below it.
Old 05-13-2013, 08:50 PM   #11
Rewards Points: 280
Fastening Durock next generation
I am asking a lot of questions lately! Anyhow some how I got it in my head (those voices again) that Durock should not be fastened closer than one inch from the edge of the panel. I have read a bunch and can find no reference to it?
My inside corners are 2X4 so 1/2" sheet on one wall leaves only one inch on the other. So would be closer than 1"
Is it OK to fasten closer than 1" from edge of Durock Next Generation? JIm
jjrbus is offline   Reply With Quote
Some uneven spots on backer board scotte1975 Tiling, ceramics, marble 5 02-24-2012 01:55 PM
re-using concrete backer board caldew Kitchen & Bath Remodeling 2 02-24-2012 06:36 AM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 01:16 PM
Backer Board Around Tub Deteriorated devnull88 Building & Construction 3 05-16-2011 09:18 PM
Backer Board Thickness poolecw Flooring 3 10-09-2008 01:30 PM
