Backer Board To Drywall Seam Issue - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 07:35 AM   #1
Backer board to drywall seam issue
I am replacing acrylic garden tub with 60 x 36 shower. I bought an enameled cast-iron base. I am tiling the walls. The shower base is exactly 60" wide. The shower space (2 x 4 to 2 x 4) is 60 3/8" wide. 1/2" backer board will be used as the start for the shower walls. It runs into 1/2" drywall. My problem is the extra 3/8" space on one-side. I do not want to rip the drywall out and run a 3/8" filler along the whole wall. Is there another way to handle this?
mojo1122 is offline   Reply With Quote
Old 05-02-2013, 08:49 PM   #2
DIY staff
Rewards Points: 7,174
The walls need to match the width of the base---so--sister in 2x4 or fir out the wall--those are your options---
Backer Board Around Tub Deteriorated. devnull88 Plumbing 2 05-18-2011 03:56 PM
Backer Board Around Tub Deteriorated devnull88 Building & Construction 3 05-16-2011 09:18 PM
Green board, blue board, backer board??? ddougee Remodeling 5 03-21-2011 09:58 AM
where tile backer meets drywall rtoni Building & Construction 11 01-07-2011 09:05 AM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
