Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 06-19-2009, 01:28 PM   #1
Attaching wood corbels to tile......
I have two corbels for either side of my exhaust hood in my kitchen. I also have a tile backsplash.
The corbels are wood and have "key slot's" recessed on the back for hanging BUT I can not use screws to attach, I need to use some adhesive.
I was told they could be glued up, but not sure what I can use.
Any advise?
They look something like this:
www.invitinghome.com/Corbels/corbel_grape_large_r40xl.htm
dcd22 is offline   Reply With Quote
Old 06-20-2009, 08:42 PM   #2
Why can't you use screws, drill through the tile, how heavy are they and are they supporting anything?, maybe an epoxy or good construction adhesive, not sure.
R&D Tile is offline   Reply With Quote
Old 06-22-2009, 11:32 AM   #3
I would not be able to get them flush up against the hood.
The hood is in place, the corbels have key slots for the screws. I would need to get the corbel higher then the hood and slide it down, cant do that.
I was told a heavy duty construction adhesive. No, they are not supporting anything.
Old 06-22-2009, 07:18 PM   #4
Tileguy
Bud Cline's Avatar
If the corbells ar strictly for decoration use 100% silicone. Push them in place and hold them there with sticks and tape until the silicone dries.
Tile with a wood trim? trick29392 Flooring 3 06-26-2008 08:19 AM
tile on tile? kshankle Flooring 37 06-23-2008 06:04 PM
Attaching Granite to Wood leted_82 Building & Construction 7 09-26-2007 12:52 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
