Any Tips For Grouting Textured Tile? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 01:39 AM   #1
PatrickGSR94's Avatar
Rewards Points: 87
Any tips for grouting textured tile?
Just laid my slate-look porcelain tile this weekend, and grouted one area tonight so we can get appliances back in place. A major issue we ran into was the grout (dark gray, looks black when wet) getting into all the small pits all around the edges of the textured tiles. Are there any tips or tricks for making grouting these sorts of tiles easier?
I always see how-to's on grouting smooth glazed wall tile or smooth floor tile, but this textured stuff is just a nightmare! We only grouted about 70 s.f. out of 206 s.f. and I'm dreading the rest. Wife was like "can we just not grout it?" and I was like uhhh no that would look awful But the tiles themselves just look sooo good before grouting, and after they seem to look kinda blahhh.
PatrickGSR94 is offline   Reply With Quote
Old 03-20-2011, 11:20 PM   #2
I'll give this thread a bump because I have the same question.
Sorry I can't help you Patrick. Let's see if someone else has a tip for us...
-Jay
jbarker is offline   Reply With Quote
Old 03-21-2011, 02:15 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Not an expert here, but I would think about using a grout bag. Sorta like an cake decorating/icing bag.
Old 03-21-2011, 03:17 PM   #4
Five Star User
You can get an acrylic modified grout in a caulking tube if you are having an issue.. but really it shouldn't be an issue if you know the proper technique for grouting. I am guessing that you are getting it too soft/wet or too dry and then you will have more stay in the areas that you don't want it. Also make sure that you clean the water regularly.
indymaker is offline   Reply With Quote
Old 03-21-2011, 04:15 PM   #5
Rewards Points: 87
I have found that not waiting too long before starting to clean helps get the grout out of the pits around the edges of the tile. It's still more work than grouting a smooth tile, but it's getting easier the more I do it.
Old 03-21-2011, 06:29 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Toothbrush!
Is this real slate or simulated slate?
XXX
Old 03-21-2011, 06:52 PM   #7
Rewards Points: 87
My tile is porcelain that's supposed to look like slate.
Old 03-21-2011, 06:59 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Toothbrush.
XXX
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 07:08 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 08:06 PM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 02:35 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
Tile over, or tile under? jeffyisfive Flooring 4 01-24-2007 12:29 PM
