Another Cement Board Flexing Question-urgent! - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-19-2011, 09:26 AM   #1
Another cement board flexing question-urgent!
Hi...The cement board in tub alcove installed at the plumbing end consists of two sheets one laid horizontally and one vertically, the horizontal
one is fine there is no flex, but the vertical one below it has some flex in it at the top. Is
this going to cause problems with the finished tile work cracking? If so, can
anyone suggest a fix that doesnt involve taking down the vertically installed piece of cement board.
porchhen9 is offline   Reply With Quote
Old 07-19-2011, 01:25 PM   #2
jules4's Avatar
I'm no tile expert, but since no one else has replied to your "urgent" question yet I'll take a stab at it.
Originally Posted by porchhen9 View Post
The cement board in tub alcove installed at the plumbing end consists of two sheets one laid horizontally and one vertically, the horizontal one is fine there is no flex, but the vertical one below it has some flex in it at the top. Is this going to cause problems with the finished tile work cracking?
Hell Yes that's going to cause problems.
If so, can anyone suggest a fix that doesn't involve taking down the vertically installed piece of cement board.
I think you have to take it down.
Theoretically it might be possible to avoid taking down the cement board by screwing plywood into the studs over-top of it, and then installing new board on the ply, but that would be nuts.
jules4 is offline   Reply With Quote
Old 07-19-2011, 05:05 PM   #3
DIY staff
Rewards Points: 7,174
Your picture doesn't show many screws--Do you have screws every 9 inches ?
Old 07-19-2011, 05:10 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
can anyone suggest a fix that doesnt involve taking down the vertically installed piece of cement board.
You're kidding...right?
What is the spacing between the wall studs? I'll tell you what it is. It is too great to support the wallboard properly. Take the board down and install some cross-members or whatever you have to do to correct the framing. The board will not safely span more than 16" Stop looking for shortcuts.
I also know the answer to that question.
The answer is a resounding "NO". Yet another shortcut.
XXX
Old 07-19-2011, 05:15 PM   #5
DIY staff
Bud-----------
Old 07-19-2011, 05:18 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
XXX
Old 07-19-2011, 05:54 PM   #7
DIY staff
Must be the hot weather--I had a thread shut down today at CT for dressing down someone.
Some times I have trouble holding my tongue
Old 07-19-2011, 06:04 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Glad that hasn't happened to me.
Yet today.
XXX
The Following 2 Users Say Thank You to Bud Cline For This Useful Post:
oh'mike (07-19-2011), porchhen9 (07-19-2011)
Old 07-19-2011, 09:17 PM   #9
I thought I might have to rip down the cement board and beef up the . Just
thought I would ask. I will have to call the contractor and get him back
in, this p-sses me off. Yet another delay.
Old 07-20-2011, 05:59 PM   #10
Hey Bud ....I needed that hand slapping. Taken cement board down. Installed 2x4 horizontal bracing behind the two pieces
and at the bottom behind cement board and "voila" problem is gone. Now I just need to tape and thin set joints and I can get
on with tiling.
Old 07-20-2011, 06:03 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
on with tiling.
Okay...you don't have to go to "Time Out" this time but you are on notice.
Wait until you are installing the tile to tape and bed the joints otherwise you will have hard humps you don't want. Remember: NO SHORTCUTS.
XXX
PVC cement question - the glue doesn't seem to work whiskers General DIY Discussions 3 05-20-2011 11:27 AM
1/4" cement board "does not exist"! benr Tiling, ceramics, marble 5 04-08-2011 02:23 PM
question about cement board Tenchi Building & Construction 2 11-21-2010 09:13 PM
Urgent Kitchen flooring question!! TravisBlake Flooring 4 06-02-2010 09:57 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
