Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 07-19-2012, 03:55 AM   #1
advice on entryway tile subfloor
I am renovating my living room and wanted to expand my small tile entryway into the living room.
Currently there are 4x4 tiles that will be removed. They are on a .5" plywood subfloor with .5" plywood as an underlayment. The tile and underlayment will be removed and I will put plywood back down so the entryway floor and the living room floors are level.
The living room subfloor consists of .5" plywood with .5" chip board on top. (Its not OSB. It looks like MDF but with larger fibers.)
What I'm wondering is can I put my cement board down on top of this? Or can I sandwitch it with a piece of .375" plywood then the concrete board?
I am installing 12x12 ceramic tile. About 40 sq ft.
Novice_DIY is offline   Reply With Quote
Old 07-19-2012, 08:37 AM   #2
I would get rid of all of that down to the floor joist. Install Advantec subflooring, then Subfloor rated 3/8 plywood, 1/4 tile board set in a bed of thin set spread with a toothed trowl then the tile.
Old 07-19-2012, 05:03 PM   #3
Why go down all the way to the joist? Why not leave the plywood sub and add the rest on top? Is it for floor height or something else? Im just curious. Thanks for the reply.
Old 07-19-2012, 05:23 PM   #4
1/2 plywood and what ever that junk is they used is not a sutable subflooring for tile. Tile can not flex at all
Question for JazMan - Subfloor / underlayment - Ceramic Tile benr Tiling, ceramics, marble 1 03-03-2011 11:26 PM
New tile in entryway now 'flush' with door threshold. Need ideas 211 Flooring 8 01-13-2011 08:37 PM
Fixing Noisy Subfloor (No Tile) Todd85 Flooring 5 05-12-2010 05:14 PM
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 10 01-25-2010 11:01 PM
Is it ok to let Ditra set to subfloor today, then lay tile tomorrow? creamaster Flooring 3 05-23-2009 06:29 PM
