Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 04-23-2012, 05:56 AM   #1
sweaty
Adding Layer of Caulk to Tile?
We had our bathroom renovated this past summer. Our new shower stall has a plastic base and ceramic walls. The caulking at the bottom seems to dip. It forms a low point where water collects and gets mildewy quickly. Can I add a layer of caulk to this or must I remove the old caulk completely and start over? What kind of caulk should I use?
sweaty is offline   Reply With Quote
Old 04-23-2012, 07:11 AM   #2
Remove the old caulk completely, with a razor blade or similar. The wrong type caulk was installed. Silicone caulk specifically made for bathrooms has a mildewcide in it which slows or stops mildew growth. That is what should be used.
There are a number of ways to smooth that caulk bead so there is no place for water to pool. I just use a finger, but some used a wetted finger, spoon, another type of curved tool, etc. Kepp a rag or paper towel to keep wiping the tool so the caulk does not pile up behind it. But don't put in too large a bead.
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Adding tile to a bowed wall Raball Drywall & Plaster 2 08-25-2011 08:00 AM
Adding clear silicone over grouted caulk for more waterproofing Louise Yarber Remodeling 4 04-23-2011 10:21 PM
Bonsal tile & grout caulk tube biancagrayling Tiling, ceramics, marble 2 02-22-2009 02:48 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
