Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 07-30-2012, 11:58 AM   #1
3-Part Leveling - Thinset, Backer Board, SLC
My laundry room flooded due to an exterior leak and I had to pull up the vinyl. Under it I found up to 1.25" of wet, mildewed, compromised, putty-like SLC. Below it is another layer of vinyl with the top layer removed that was glued to the slab. It would seem that the builder tried to get away with with a floor that sloped 1.25" over an 11' run, got called out on it, pulled off the wear layer of the vinyl, leveled the floor and put new vinyl on top.
Because the SLC was waterlogged for who-knows-how long, it was totally compromised and I had to tear it out. I am getting ready to tile my laundry room and need to level the floor again. I have two concerns - a 1.25" thick pour of SLC and that I will need about 8-9 not-so-cheap bags of it.
So far I've removed as much of the bottom layer of adhesive as I could and etched the slab where the etch was able to get to it. Instead of using all SLC, can I build up the really low areas with backer board thinsetted to the slab, then finish the last 0.25" or so with SLC?
Banttari is offline   Reply With Quote
Old 07-30-2012, 12:07 PM   #2
Super Moderator
Use SLC---thinset is the wrong product---
Read the bag---sand can be added to some SLC products to add bulk and cut costs--
I like Jifset mixed with Linewebber liquid latex---for the first coat---additional layers get mixed with water.
The soft stuff you remove might have been gypcrete---soft and similar to drywall in strength and composition---
Tags
backer board, self leveler, self leveling compound, thinset
Hardie backer board textured with thin set wildwort Tiling, ceramics, marble 14 11-21-2011 11:01 AM
Backer Board Around Tub Deteriorated devnull88 Building & Construction 3 05-16-2011 10:18 PM
OSB - Cement Board & Leveling 04snr Flooring 8 01-24-2011 06:32 PM
Cement backer board wadeseward Flooring 16 09-10-2010 12:34 PM
bryant inducer board part number? boomerbaird HVAC 3 01-03-2008 06:54 PM
