12x12 Wall Tiles?? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-15-2009, 09:48 AM   #1
12x12 wall tiles??
Hi , I have done a bunch of floor tile but I am now attempting to tile a tub surround and have a few questions. I put up a kerdi membrane for waterproofing. I plan on using 12x12 porcelain tile. My big question is are there any tricks to keeping the tiles from sliding as I install them? Thinset doesn't seem like it will just hold them immediately, although I know its the right product to use. Also am I correct that I should butter the tiles as oppossed to spreading the thinse on the walls? Thanks and any other suggestions would be appreciated.
bekind is offline   Reply With Quote
Old 09-15-2009, 06:17 PM   #2
Start at the tub level leaving a 1/16 to 1/8" gap and use spacers as you go up, nothing to it.
The gap gets caulked after grouting.
R&D Tile is offline   Reply With Quote
Old 09-15-2009, 10:00 PM   #3
Remodeler
MinConst's Avatar
Use an epoxy thinset with porcelain. The spacers will do the trick.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-15-2009, 10:09 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 244
Absolutely no need to use epoxy. I think maybe our construction friend meant to say modified thinset mortar? If so, he is still wrong because the porcelain is going over Kerdi.
The thin set should be spread on the Kerdi with the proper notched trowel, there is no need to butter the tiles too, but won't hurt unless you apply too much.
Jaz
JazMan is online now   Reply With Quote
Old 09-15-2009, 10:20 PM   #5
Jaz,
I knew the kerdi used the unmodified. I assume a 1/4 x 3/8 trowel is correct? I was just worried the tiles might slide as I put them up but apparently I was wrong about that. Thanks everyone.
Old 09-16-2009, 06:34 AM   #6
They will, unless supported.
Old 09-16-2009, 09:46 AM   #7
so what just use 1/8 piece of wood under the bottom tiles and thats it?
Old 09-16-2009, 02:01 PM   #8
I use spacers, there are all kinds that will work, also depends on whether or not the tub is level, the tile has to be level, even if the tub isn't.
Old 09-16-2009, 04:55 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 244
Yup they'll slide as you already know. Spacers or whatever is handy will be fine. 1/4x3/8x1/4 is my choice. Make sure you buy a good quality unmodified thin set if you wanna follow Schluter's directions.......so no shopping at the orange vest place.
Jaz
Old 09-17-2009, 12:38 AM   #10
Rewards Points: 150
organick is offline   Reply With Quote
Old 09-17-2009, 09:53 PM   #11
Tileguy
JazMan's Avatar
Rewards Points: 244
Oh great, a blank edited response.
Jaz
another tile question: installing large (1'x2') porcelain wall tiles diy'er on LI Tiling, ceramics, marble 4 09-16-2009 02:57 PM
Fixing small area of tiles on the wall Curious123 General DIY Discussions 3 09-09-2009 08:41 PM
Water seeped through tiles in shower, wall ruined, need help. doogie88 Building & Construction 39 10-07-2008 05:13 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Replacing damaged shower wall tiles kevind Remodeling 3 11-15-2006 11:36 PM
