1/4" Cement Board ? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-27-2015, 09:21 AM   #1
Rewards Points: 6,040
1/4" cement board ?
is there any negative issues with this ? i am pondering/planning my kitchen/dining room flooring. i know 1/2 would be better. but a minimal transition would be beneficial. this would be over 3/4 plank sub with 1/2 ply on that.
also. my kitchen and dining have a 1/8" difference. could i put thicker layer of thinset (or whatever its called) under the CB to make up the difference ?
Fix'n it is offline   Reply With Quote
Old 08-30-2015, 05:26 PM   #2
firehawkmph's Avatar
Rewards Points: 1,468
I wouldn't worrying about the floors matching up perfectly when they're that close. I always use some sort of transition threshold. For tile I like to use marble thresholds with a bevel on each of the long edges. Instead of the 1/4" cement board I would recommend using Ditra by Schluter. They have two different thicknesses available. Good product and easy to work with as long as you read and follow directions. Videos available on their website.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Fix'n it (08-30-2015)
Old 09-01-2015, 11:18 AM   #3
Rewards Points: 4,744
No problem with 1/4" vs. 1/2" CBU. But anyway, Ditra. If there is a height issue at the transition, yes you can make that up to a small extent with thinset under the tiles at the edge.
jeffnc is offline   Reply With Quote
Old 09-01-2015, 09:39 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 4,716
Actually " is preferred and made for floors. I agree that Ditra would be my preferred way to go though. Alternatively if you wanna keep the floor lower, you could removed the planks and install " subfloor instead, but that's more work.
.....also. my kitchen and dining have a 1/8" difference. could i put thicker layer of thinset (or whatever its called) under the CB to make up the difference ?
No, that's not gonna work so good. You might try several layers of tarpaper laid in a ramping fashion or apply a bit of thinset over the cbu, then backbutter the tiles a bit too. Need to be careful not to create a new hump.
Jaz
MARBLE from ITALY & GREECE - PERLATO - PERLATINO - BOTTICINO - THASSOS - SIVEC - VOLAKAS - CALACATTA - NAXOS - Slabs - Tiles - Custom containers marmo.sicilia@yahoo.com
The Following User Says Thank You to JazMan For This Useful Post:
Fix'n it (09-02-2015)
Old 09-01-2015, 09:50 PM   #5
Sorry, I missed that you said CB here. I answered "yes", then talked about putting it under the tile, not the CB.
You can't put more thinset under CB because it's screwed down tight to the floor. In general you can put more thinset under tile in certain situations - specifics depend on the details.
The Following User Says Thank You to jeffnc For This Useful Post:
Old 09-02-2015, 08:17 PM   #6
thanx fella's. i am working to finish my laundry/1/2 bath room ( i seriously underestimated this room). but it should be pretty much done this weekend. then i will be seriously looking to do this dining room/kitchen floor. i still do not know if it is flat enough for tile.
Type nails? - wooden trim into cement board Easypick Carpentry 5 07-21-2013 03:16 PM
question about hanging cement board in shower pillowshack Drywall & Plaster 0 01-12-2013 06:55 PM
Installing Stone Veneer to cement board on a wall Augy Building & Construction 2 01-20-2012 06:17 AM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 08:29 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
