Zero Entry Shower On Concrete Pad - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 05:58 PM   #1
Zero entry shower on concrete pad
I am remodeling my master bathroom and want to do a zero entry shower. What do I need to do to install this type of shower? The drain is in the middle of the pan currently.
dkealy is offline   Reply With Quote
Old 07-19-2010, 06:56 PM   #2
DIY staff
Rewards Points: 7,174
By zero entrance---do you mean curbless?
If so you will need to cut open the slab --remove the concrete in the new shower area---add a new floor drain just outside of the shower-
Add a new shower drain(Schluter is the easiest) build the new pan with deck mud--sloped to the drain.
Add your backer to the walls---patch all voids with thinset--Then waterproof the walls/pan/bathroom floor,with HydroBan by Latacrete.--
That is a very brief description of the steps in building a curbless shower on a slab.---Mike---
Old 01-11-2012, 02:45 PM   #3
1) I'm looking to do a curbless tile shower in my remodel. I've toured several new model homes in the area to get ideas and have not seen a floor drain outside the shower. Is this necessary?
2) My home was built in the 70's, and there is no membrane installed in the current shower. I had planned to install a new drain (will have to relocate it a short distance to be in center of new shower) without the use of a membrane. This is a first floor (no basement) installation. House is on a slab. Is there any reason why I can't forego the membrane?
3) I'd like to tile the bathroom floor to the same level as the shower entrance so there's a smooth transition. What is the correct way to elevate the bathroom floor before tiling? Can I just glue concrete board and fine adjust with the thickness of thinset as I lay tile?
Falconag is offline   Reply With Quote
Old 01-16-2012, 10:28 PM   #4
Repost anew
I think you'll get more help starting a whole new thread.... rather than adding to one essentially finished.
bareshiyth is offline   Reply With Quote
Concrete shower? secutanudu Building & Construction 4 01-14-2010 06:33 AM
Shower pan/tile against concrete wall mgray87 Tiling, ceramics, marble 10 09-11-2009 11:50 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Do we have to break the concrete floor for a shower drain? Mechelle Plumbing 41 07-30-2008 08:59 AM
Concrete Board in shower, need help please! floxy General DIY Discussions 18 03-01-2008 06:15 PM
