hi all,
new member here.
let me start off with my situation. Tiles in my shower decided to just fall off.
after checking into why, i discovered that the tile was installed using construction adhesive and not from properly using thinset.
after tearing all the tile down i have was appears to be cement board ontop of drywall.
now i have read other replies on this site about the same topic, a bit older but i just want to make sure i understand correctly what i read. So here goes my questions..
#1 to make up the thickness of the old drywall, cement board and the title combo that was removed i would like to put it back that way to maintain the thickness so there isnt a gap between my wall and tub, so if i put drywall up i need plastic sheeting on top of the drywall, then on goes the cement board. Am i correct on this? if not please correct me.
#2 if this is not a good idea, how can i maintain the thickness of the drywall, cement board and the tile without leaving a gap between the wall and tub.
#3 is it regular drywall that was used for behind the cement board or is there special drywall to use in a bathroom?
#4 im considering redoing the other wall (across from the tub, it has ugly tile on them) is regular drywall ok to use for this or do i need a special drywall for this as well?
im handy at the DIY stuff, but taking on a re-tile is new for me.
would appreciate any step by steps anyone can provide
new member here.
