Worktop On A Hanging Cabinet - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-23-2010, 03:47 AM   #1
yak
Worktop on a hanging cabinet
We're redoing our bathrooms.
We need to install a CaesarStone(quartz) worktop of 2.7mX0.6m (~50kg/m) on a hanging cupboard unit. Need an advice to achieve sufficient strength.
yak is offline   Reply With Quote
Old 04-23-2010, 07:19 AM   #2
Not enough info..........quartz tops are heavy and need a solid mounting surface. A pic of better description might help.
Old 04-24-2010, 06:15 PM   #3
yak
Attached a sketch
Please see the sketch I attached. I hope it gives more info
Old 04-24-2010, 08:31 PM   #4
DIY staff
Rewards Points: 7,174
If that box unit is strongly constructed --the side walls will give plenty of support for the size slab that is planned.--Mike--
Old 04-24-2010, 09:07 PM   #5
Seems like its going between 2 walls ?
If so & you can secure into studs you should be fine
Old 05-02-2010, 07:22 PM   #6
yak
Secure system
Thanks guys.
Indeed it's going between 2 walls, however, the length (2.70m) made us worry than there may be a droop at the sink area and the counter top might break.
Eventually we have decided to add 2 steel supports.
Drawer Slide for Cabinet w/o back george0410 Carpentry 2 04-08-2010 06:53 PM
Cabinet hinges don't fit... arghhhh!!! pisces7378 General DIY Discussions 7 12-25-2009 08:47 PM
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 11:08 PM
Under cabinet Light Suggestions jamiedolan Electrical 7 04-01-2009 12:59 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 11:59 PM
