Wood Backsplash? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-30-2014, 10:46 AM   #1
Question
Wood backsplash?
I am redoing our kitchen... on a VERY tight budget... I am stuck on ideas for back splash...
I received "30" 24 inch fence boards... They are 5/8" x 5 1/4 (I think) and 2 foot long... They have never been used... Only cut down to 2 foot...
I was wondering if these could be sanded, stained or paint, poly'ed and used as back splash...
Any ideas? Helpful hints?
Any help much appreciated!
Thanks!
JulsGo is offline   Reply With Quote
Old 06-30-2014, 11:36 AM   #2
Rewards Points: 444
The first step is to determine if they are treated against insect infestation.
If not, I see no reason why they couldn't be used. I can hear the screams now. Good grief, that's a wet area, but really how wet is it and for how long. I would do an edge lap joint and treat with hot paraffin for a finish on every surface and end grain before installation for a natural look or paint a favorite color.
Old 06-30-2014, 11:41 AM   #3
Rewards Points: 144
As they dry they will probably twist all over so it would be hard to get them to conform to your wall.I understand budgets as much as anyone but think it's a bad idea.
mako1 is offline   Reply With Quote
Old 06-30-2014, 11:43 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 840
Ditto...
I think you would be better off with a nice heavy coat of enamel paint until the budget allows otherwise.
Old 06-30-2014, 11:43 AM   #5
Thanks Fairview... At first I thought about the wet area but again, like you said, it wouldn't be wet for long (if it got wet).. I am thinking painting them... Thanks for the help!
Old 06-30-2014, 11:52 AM   #6
Old 06-30-2014, 12:03 PM   #7
Rewards Points: 444
If cupping is a concern, as most of today's lumber is, cut a kerf the length about 2/3 the lumber thickness deep and spaced about an inch apart on the back side. That will usually relieve any cupping stresses. The back side should be that which was the interior of the tree. Looking at the end grain will tell that story.
Old 06-30-2014, 12:50 PM   #8
Great! I appreciate all the help!
Tags
back splash , kitchen , wood back splash
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
