Will This Glass Match Our Bathroom? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-28-2009, 03:27 AM   #1
Will this glass match our bathroom?
Painted in 1990 and now our bathroom look so old and the wall is off the origianl yellow color.
I have found a yellow color glass tile to match our bathroom. Please have look at the tile and give me some advice.
http://www.builderelements.com/shope...ems#startorder
My original intention to find a yellow glass because i do not want to repaint the wall so that i could lower down the cost. But as you could see that the tiles are transparent, i am afraid that after i have the tiles installed, the original wall color will be see through from the glass. If so, our glass will become a waste.
So could anyone give me some advice? Thanks!!
EmmaZhao is offline   Reply With Quote
Old 08-29-2009, 10:20 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I'm sure any experts here will correct me if I'm wrong, but I believe glass tiles are installed with a special white thinset.
After proper installation you will not see any of the original wall color. Depending on the transparency of your tiles, at most you will see the white thinset under the tiles. And, of course, your chosen grout color between the tiles.
FWIW, I know it may save you a couple of bucks now, but I would choose the tile based on what I love rather than the current wall color. If you go with yellow tile, you are pretty much stuck with a yellow bathroom forever. If you go with a nice neutral, well... paint is actually one of the cheapest changes you can make, especially compared to glass tiles.
Old 08-30-2009, 09:02 PM   #3
Thank you for your advice!!
We really could not afford to take the risk! Wish repaint the wall as our first job.
Old 09-20-2009, 07:37 AM   #4
I suggest you to check these Shower Screens. I hope it will help you to make look your bathroom excellent. Thank you.
____________________
Get a quality trampoline here.
trammaster is offline   Reply With Quote
Old 09-21-2009, 03:03 PM   #5
Remodeler
KlintP's Avatar
This is good advice. Paint is about $30 a gallon, and it sounds like you need to repaint the walls whether you stick with yellow or pick a new color.
KlintP is offline   Reply With Quote
Tags
bathroom , glass tile , yellow
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 07:37 AM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
Help with replacing some glass shonkster Building & Construction 5 03-12-2009 05:24 PM
Glass Block in Bathroom oxicottin Remodeling 2 04-21-2008 03:09 PM
