Where To Start Tile - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 08:42 PM   #1
Where to start tile
I've seen it both ways 1. mark the center vertical and horizontal and start tile from the mid point. 2. start at the bottom just above the tub so that there are not cuts next to the tub.
Seems like it wouldn't make a difference. I like the idea of fewer cuts.
What is the "right" way?
DIYGuy2012 is offline   Reply With Quote
Old 04-22-2012, 09:37 PM   #2
Missouri Bound's Avatar
#1 is the right way on all tiling jobs.
Do you want it your way or the right way?
Old 04-23-2012, 10:44 AM   #3
Thanks, any particular reason why? Seems like having no cuts at the bottom would look better.
Old 04-23-2012, 10:58 AM   #4
Where to start tile
I lay a level on the Tub to find the low spot. Even the best plumber who sets the tub can't account for twists and tweaks that inherent with all tubs.
To have an even grout joint at the tub, you have to draw a level line all the way around starting at the low spot with a full tile, and the cut in where the tub is higher.
Some times you get lucky if the tub isn't out of level much.
NickdaGreek is offline   Reply With Quote
Old 04-23-2012, 05:04 PM   #5
Well I put the tub in so of course it is perfectly level
One thing that struck me as to why you start at the mid point intersection is so that the tiles at the bottom would be cut the same as the tiles at the top and wouldnt look funny. But since I can stop anywhere I want to at the top that wont matter. I am going to save myself some cuts and start at the bottom - using the level line at the low point.
Old 04-23-2012, 07:39 PM   #6
Stay-at-home GC
Starting near the middle reduces the effects of cumulative error as well.
You may not always want to bisect your tile field with your reference lines. The goal is not so much even tile sizes on the edges as it is about deciding which layout works best for a room.
Decide where the focal point of the tile field is and use your reference lines to ensure the best presentation of the tile at that area. For example, on a bathroom floor you would want the tiles along the tub to be full size or almost full size while your last row behind the toilet and under the vanity toe kick can be much smaller.
Good luck and let us see the results.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 04-24-2012, 06:55 PM   #7
firehawkmph's Avatar
Rewards Points: 1,858
Not necessarily. Mark the center then check and see how the tiles run out and what your end cuts will be. Sometimes it is necessary to shift the whole layout a half width to eliminate skinny pieces on the end. Very similar to drop ceiling layout. I don't want to see slim cuts at the ends.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-24-2012, 06:59 PM   #8
Mike Hawkins
Hello
shasha is offline   Reply With Quote
Tags
ceramic tile , tile , tub , tub and shower
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
Installing Hardwood Floor butting up to tile Macker Flooring 3 01-02-2011 03:21 PM
Subfloor and Porcelain tile prep sugarhousemama Flooring 4 12-03-2010 06:47 PM
Laying tile, always start from the center? Or will a corner do if the walls are OK. abefroman Flooring 6 10-23-2010 08:53 PM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
