Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 10-29-2012, 08:50 PM   #1
Whats the best way to remove grout?
I am looking to re-grout my shower. Its tub sized with 4"x4" ceramic(?) tiles. I would like to remove all of the grout and add fresh grout. This is our only shower so I need to get this done without spending more than weekend of so. I have experience grouting, just not sure what to expect removing the old stuff.
What is the fastest and best way to remove the grout? I have a dremel. Is an oscillating tool better? hand grout saw?
How much time can I expect remove it all?
Thanks in advance
Total Tool is offline   Reply With Quote
Old 10-29-2012, 08:57 PM   #2
I'd use the ossilating saw with the diamond grit blade.
Not sure how your going to remove it, install new, give it time to dry and seal it all in one day.
Old 10-30-2012, 09:10 PM   #3
I dont want to do all of that in one day. I'd like to remove the old grout in a few hours (hopefully?), clean it up and grout the next day. I'm assuming I can tape up some plastic to cover the new grout and still be able to use the shower.
Is that a reasonable assumption?
Old 10-30-2012, 09:24 PM   #4
Super Moderator
If those are the 4 1/4 x 4 1/4 tiles that were popular for so long--the grout line is to narrow for an oscillating tool with a diamond blade (good tool if the grout line is wide enough)--
For those thin line---a utility knife is the tool of choice--the unsanded grout comes out easily enough---
Sorry---no power tools for the tile with the narrow grout lines----
Old 11-08-2012, 05:26 PM   #5
Barry
Some of the oscillating tools have 2 different sized diamond blades - a thin one and a thicker one. I've used the thin one successfully on thin grout lines. Make sure you get a variable speed tool, and be very careful! It's very easy to cut the tile or leave marks on it if you're not extremely careful. Do yourself a favor and get a good quality tool. Forget cordless - they won't have enough power for a grout job.
Barry
Tub Refinisher is offline   Reply With Quote
The Following User Says Thank You to Tub Refinisher For This Useful Post:
oh'mike (11-08-2012)
Sanded or unsanded grout for the shower surround wall tiles? nitting Tiling, ceramics, marble 10 11-30-2012 09:45 AM
How can I remove grout sealer white taint? sukhenkoi Kitchen & Bath Remodeling 2 07-29-2011 11:52 AM
Wait to seal if I need to remove haze on grout lines? PatrickGSR94 Tiling, ceramics, marble 2 04-07-2011 10:05 PM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
Polyblend 'Grout Renew' - any experiences? spidrw Tiling, ceramics, marble 0 04-22-2010 01:37 PM
